Sponsored by: CARiD
1985 Toyota 5 speed 4x4 22r: trans
Old Oct 11, 2012 | 06:19 PM
reckless stompaz's Avatar
When my truck is in neutral i can push it forward but when i try to push it in reverse it locks up still in neutral what could it be need help
Old Oct 12, 2012 | 07:18 PM
leetom101's Avatar
Locked Front Hubs?
Old Oct 12, 2012 | 08:42 PM
rokblok's Avatar
Rear brake problem? Shoes grabbing due to self adjust mechanism jacked up? Or e-brake causing probs?
You're sure it's trans?
Old Oct 12, 2012 | 11:09 PM
Not sure what it is it seem like a rearend problem not trans
Old Oct 13, 2012 | 07:34 AM
rokblok's Avatar
I would inspect the rear brakes. Pull the drums off and inspect brake mechanicals. If that visibly appears ok, then, while in neutral and drums still off, turn the driveshaft in both directions to see if your problem is actually in the 3rd member(gears).
Nathan_F
Aug 19, 2015 04:03 PM
ZONAYODA
Jun 30, 2015 05:36 PM
Eagle564
Jun 23, 2015 11:29 PM
bobbybouche
Jun 18, 2015 10:22 AM
JaredL
Jun 16, 2015 04:47 PM
