View Full Version : Newbie Tech Section
- stock wheels or some new steel wheels? wheel spacers?
- Cam ?
- Cold air intake only two hoses help please
- quick question...22re head on 22r block.
- toyota e-locker question
- valve adjustment for T100 do I need it?
- Door glass from four runner fit pickup?
- 1999 4Runner production date
- Best budget lift for 01 tacoma 4x4?? 2.5-3"
- Truck wont start-
- bucking 2.7 4x4 5speed
- Engine dies when gets hot
- setting timing from scratch on rebuilt 22r
- advice on removing auto transmission
- What muffler should i put on an 89 yota for a loud sound?
- How to put ac in my 91 toyota pickup?
- 1995 22RE Rebuild
- body lift accessory/install help
- 92 toyota pickup in consistant power loss hesitation misses
- Still Losing Oil
- need some lift info\tech questions
- Leaking Rad - Bubbles - 1KZ Help!
- lost power
- brake drum seized on and unable to move brake adjuster
- Remove crankshaft with engine mounted?
- running rough no power
- yehaw 1988 runnin good!
- 98 4Runner replaced batt cannot start, headlights work dashlights do not
- 1990 4Runner fender trim
- cats= more hp?
- What trucks had 3.4 gears?
- SAS resources for 4R on yotatech?
- 22r to 3.4
- Replacing a 3.0 what are my options?
- Conflicting information on new set of wheels
- 93 4 runner e-test help...
- what type of hub is this
- burning oil, only off camber?
- sound deadener ???'s
- aftermarket radio install no rear speaker sound??????
- 93 4x4 front clip
- Rear end making noise
- timing chain
- Driveshaft go bye bye
- Fog Lights not working 2000 4Runner
- Help! Problems installing OME lift front struts...
- Anti-sway bars and Suspension Lifts?
- OME springs with bilstein HD shocks?
- new shocks for lift
- 1986 22r building pressure in cooling system
- bye bye Extra Cab....
- 87 4runner auto to 89 manual???
- How does the temperature sensor work?
- It's working! Thank you to all esp ZUK!
- Tilt steering conversion in a 97
- Trail-gear classic lift w/blazland up front?
- Now two motors with lower end knocking
- 3.0 idle speed ?
- 95 4runner lift
- How to PM
- help missing fuel line?!?
- 3rd Gen 4R rear coolant line bypass pics?
- Powerless 4runner
- 88 good shape
- to much negative offset
- Brake issues...lspv?
- towing 91 4runner
- Leak from Transefer case to driveshaft part 2
- 97 4runner Clutch Question
- P0171 and engine stalls when pedal is
- Welding a shock mount, have some questions.
- toy tech 3 inch lift tire/rims
- Bucking at2500 to 3000rpm in 2000 tacoma 4x4
- Looking for a Compact Tacoma, some questions.
- 91 Runner wont start if warm
- THREE BOND 1324 or equivalent to Loctite Blue 242
- Sticky Rear End ???
- Low Pressure Rear Shocks
- 97 4Runner SR5 V6 4x4 - distributor cap
- New owner of an '85 with some questions
- Help ZUK! Carrier adjusters
- 97 4runner diesel swap
- Roaring sound from Newly install Third Member
- Ask your Aisin manual locking hubs ADD auto hubs questions here!
- sas without high steer
- Where do I charge my AC?
- Gears gears and more gears with 33's
- What Coilovers and tires?
- New Shocks for 06 Tacoma
- Swapping out a 22RE
- Idle issues
- 22re Idle Fluctuates While Brakes Are Engaged
- 3.0l 4x4 high highway rpms
- Dropping the front of a 1st gen 4Runner???
- Fuel Line Question 86 carb pickup
- best place for regear parts?
- What length bump stops do I need?
- 94 v6 turning over but not firing up
- 98 tacoma with 225,000 miles
- 20r/22r hybrid ???'s
- 22re performance build help??!! 1987 4runner
- A arms to ford Twin I Beam swap 93Taco 3.4L
- 2006 Tacoma
- How do I measure for shocks?
- Good lift kit
- suspension
- TJM fit question
- 4 Runner Seats Please Help Me
- Help a newb do maintenance
- New to yotatech, have a question.
- 1st gen vs 2nd gen 4runners
- 86 ifs lift ???'s
- Rear End sag on 2gen 4runner! 4 inch lift? help!~
- How hard to put in clutch 87 4runner 22re?
- Write-up on '00 Tundra V8 Water Pump Replacement procedure?
- is my 93 yota worth fixing?
- A340H 2 overdrive gears?
- 1989 Toyota 4Runner Dash, Blinkers, Wipers, etc ALL stopped working at SAME TIME!
- where to buy new carpet?
- How do I replace a CV boot?
- 93 Toyota Pickup, ideas from knowledgeable dudes needed!
- 96 4Runner - swapping rear diffs?
- 1997 4runner in need of rehab: Where do i start
- new 22re, $1,675
- What timing chain kit to use.
- E-locker question
- First hand experience Aussie Locker and LARGE tires?
- stubborn outter tie rod end
- What diff do I have?
- Tips needed for restoring seats
- 1KZ-TE Hot Start Issue
- need help choosing a motor for my 93 pick up
- Fuel pump test??
- Sheared diff stud...
- conversion kits
- 43 inch eye to eye alcans
- 1997 4Runner seized engine
- how to make a flatbed
- Suspension overhaul
- Toy or Bug?
- Axle wrap from lift blocks
- Can anyone identify this part?
- need help, looking for under dash harness for 92 4cyl runner
- 22r coolant flow direction. Help!
- Tire question
- 89 pickup tranny question
- tires rub drive line hits yoke
- Thank you Wyoming9
- auto trans, no gears except 4wheel low
- 22 re problems
- 1988 toyota 22rec stalls out and won't start at times
- my truck sounds like a big rig?
- Trying to figure out suspension
- Engine rattling (pinging?) today. Does my oil look like it has coolant in it?
- Machining rims to fit
- Altitude adjustment
- 88 22r spittin an spuderring
- will 95.5 taco aisin hubs fit my 94 4runner???
- can some one fill me in on these dual transfer case kits
- Changing Spark Plugs and Spark Cables
- Timing Chain Questions
- Lock it up.
- brake problem
- door frame cracked - how to fix?
- Rear differential: Gasket or RTV?
- Rear Latch Stuck Help!
- Will a 97 4runner exhaust work on a 99?
- hi i need some help here!
- 1994 Toyota 22re spark plug
- 1996 2wd 4runner hub removal
- Why 21 or 23 spline? I don't get it? 4.70 T-Case Gears
- New Owner - 1992 Toyota Pickup 4x4 Newbie questions
- shifter base broken!!!need opinions
- 91 Wiring harness removal help
- Any reasons why there are GM braded parts on my 5vzfe?
- Bolt size for wheel lock
- 88 3.0 fuel pump problems?
- Underside Surface Rust
- 97 runner auto to 5spd swap questions
- Low Range Question.
- Front cv going out
- 3vze timing belt done... now won't idle, belt jumps timing
- Replaced shocks, now rear end sags MORE
- 88 4runner 3.4 swap transmission and other questions
- ignition kill switch
- installing a simple ignition kill switch
- 4runner/Tacoma and Tundra Bilstein 5100 shock Valving
- 3VZ idle problem
- ignition prombles
- OIL Pan
- Oil type question 2006 tacoma prerunner
- Issues on 92 Pickup V6 Xcab
- So for a mean street machine on 35s
- so my runner is leaking coolant everywhere
- Running boards square nuts
- ISO keyless entry
- ISO "best" aesthetic lift
- Beefy, functional bull bar wanted
- tacoma model question
- 4WD front wheel bearings
- What parts can I use off a '94 4-Runner on my '85 p'up?
- 1991 4Runner question
- Affordable 3rd gen offroad bumper suggestions?
- 4" suspension lift
- 3vze code 12
- straight axle conversion
- Aisin Carb Electric Choke Problems
- New Owner with some questions on my '89 4Runner
- Replaced fuel filter/fuel line now truck wont start
- 91 toyota Gearing help
- Choosing a locker..
- 22re starting/ idling issues
- 94 pickup pulling a atv trailer.
- resurfaced head rocking on block?
- 95 T100 Fuel System Diagram
- 2000 Tacoma won't start- Need some advice
- hole in back of my ex cab??
- is it safe to leave a jumper wire in the diagnostic port
- glue problems with my 2007 tundra labels on the truck body!
- Turning a 22RE-TEC into 22R
- Stuck in the Desert, need 22RE help, will ship free beer if you get me out
- 2003 4 runner A/C problems
- 30-40ls transmission
- winch mount question
- Buying old yota back with brake problem
- leaking antifreeze at thermostat housing.
- 85 4runner front leaf flip?
- flared fenders?
- 1UZ Mod Help
- Replacing rear shocks 89 runner
- Oil Change Tips/Hints?
- newby in trouble with tranny no reverse
- Truck won't start
- Annoying Noise
- speedometer not working
- Salvaged 1991 SR5
- Clear Lights & Paint Help
- brakes do not work
- New To Toyota Owner: IFS lift Options
- A very interesting delima......
- Can I swap 16' brake drums from a '07 tacoma onto my '91?
- Power Steering Unit Rebuild Kit
- Looking to lift my Toyota
- best bang for the buck body lift kit.
- 1999 4Runner Suspension questions
- Which lift kit for T-100? (Superlift,
- '92 4runner rear suspension links
- first time front shocks prerunner
- tire and rim size ???
- injector pulse problem
