PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55
  1. 92 4Runner not going into 4WD
  2. tranny swap ?
  3. Newb with an 87 runner
  4. need help 83 toyota
  5. rack and pinion?
  6. 81 carbed intake
  7. Is it good for SAS?
  8. how much diff oil required in rear diff?
  9. help finding information
  10. Few Questions
  11. driving lights
  12. newb wheel question
  13. Help with a SAS on my yota
  14. U-Joints 3rd gen part numbers
  15. 1988 toyota 3.0 V6 help please
  16. 1992 4RUNNER/Surf front suspension
  17. Where is the dip stick located on a 3.0?
  18. How much tranny fluid?
  19. fuel line and tank trouble
  20. 1992 Ignition Is stuck after new keys cut!
  21. How to make exhaust louder?
  22. Suspension Lift for 01 4Runner
  23. 1988 Toyota Pick-up won't idle
  24. 2004 4Runner stuck in 4 wheel drive
  25. oil seal question
  26. Recall info needed
  27. largest tires on an 86 4runner with no lift no cutting???
  28. rear diff. gear oil
  29. 22r missing part?
  30. misfire + backfire ????
  31. Transmission Replacement
  32. about time to paint the runner!
  33. The BASICS of 3rd Members???
  34. Adjusting Door
  35. frayed belts
  36. 87 4runner New Header vibration?
  37. 1996 4runner 3.4 V6 Automatic issues
  38. 22re to v6 exhaust system compatability
  39. Rear Ended a FORD...
  40. Metal head gaskets
  41. OME Coils with Bilstein HD's
  42. need and want gearsb but
  43. ?motor swap?
  44. turbo charging a 22re
  45. Tacoma 4x4 Advice Please
  46. A simple question about adding a body lift.
  47. My parking/headlight switch lights my brake lights up.
  48. Coil Spring Condition To Bump Gap Relation
  49. new to 3slow, few questions for it
  50. U-joints for the 85
  51. Front Hub accident
  52. Just picked up a 90 4runner...now what?
  53. Auto or 5speed?
  54. 2004 3400 thermostat installation problem
  55. Stupid thing wont start!
  56. Ignition Key Lock Cylinder
  57. IFS capable???
  58. Timing question......
  59. questions about gears and locker
  60. Rear e locker stuck in locked position
  61. Pinch Weld Mod (w/ pictures)...
  62. new to the site here got a ? about 2gen lift
  63. BFG T/A KM2 Muds on highway?
  64. newbie?
  65. tire question
  66. brakes
  67. wet #3 spark plug
  68. Looking for lift advice
  69. Installed coil spacers. Now i hear sounds while stopping?
  70. O2 Sensor-Help
  71. Stupid question: how do I take the fuse box out of my '89?
  72. gear help..
  73. are these cv joints any good? [ebay] im in need of them.
  74. problem with ADD
  75. New to 4-runners
  76. Lift and tires for 09' Tacoma!
  77. 2003 4Runner Limited Lift Question
  78. Breaking U-joints on installation
  79. Front bumper suggestions?
  80. Rear end a little saggy
  81. my toyota needs to breathe
  82. seats
  83. water leak at intake
  84. 1988 toyota 4runner axle swap
  85. TRIMMING FENDERS *3rd gen*
  86. code 43, need guidance
  87. Front diff ?
  88. Getting a 86 sr5
  89. TPS not hooked up
  90. tranny/transfercase
  91. Newb Rig Set Up
  92. Need advice about water pump test and cause of hard start on 94 4Runner
  93. frame rust
  94. Tps=bad gas mileage?
  95. Stock tires to 32" or 32.5" All Terrains???? School me!!!
  96. Not sure of the part i hold in my hand
  97. 3" body lift questions?
  98. 4runner Gears?
  99. IFS shock length and brand
  100. rear swag
  101. exhaust
  102. lockers
  103. Online Service Manual
  104. trouble in rain
  105. I need your opinions ! tires 31 vs 33
  106. simple tire rotation question
  107. fuel problem
  108. how much lift till u need longer driveshafts
  109. Can you regear at the Transfer Case?
  110. Suspension lift for 2wd 4runner?
  111. which rear end is it?
  112. T-100 engine swap??
  113. leaking 88 4x4 pickup
  114. What transmission do I need
  115. MSD Ignition
  116. Lift Needs???
  117. Really bad noise left rear!
  118. 86 4x4 frame damage
  119. Gears?
  120. 91 Pickup/4cyl/22RE/4x4- Got some questions.
  121. Antifreeze pouring out from exhaust
  122. 4.0 charger upgrade - anybody done it?
  123. sas question
  124. 4runner transfer case out at 60K miles?!?
  125. Carb and exhaust help
  126. 94 4runner 4cyl vs 6cyl
  127. Basic maintenance/ Mods
  128. truck dies when warmed up
  129. tranny question
  130. Need help, where to start!!
  131. 1993 4 runner cruise control!!
  132. 92 yota pickup 2wd Ice driving?
  133. is toyota gonna rule the world?
  134. another slow 22re...
  135. Transmission problem
  136. 22r timing problem please help!
  137. Engine Upgrades
  138. 5speed vs auto?
  139. 4cly or 6cyl? What are the pros and cons?
  140. Testing airflow meter
  141. floor jack, bottle jack
  142. Changing rear axle
  143. what makes 84-85 front axles better
  144. need some advice on oil.
  145. Toyota Newbie: 1987 4x4 Questions: IFS, Towing, Seats, etc
  146. Oil Pressure Help
  147. 96 Toyota 2.7
  148. New to Yota Tech - E-Locker?
  149. new yota owner few questions
  150. 86 pickup that will not move
  151. buying a new used 91 TOYOTA PICKUP TRUCK
  152. Timing Chain
  153. Which fuse goes to the radio in a 1989 4runner?
  154. Transmission Casting Numbers on R150F
  155. Truck dying, remanufactured injectors?
  156. Need Help with engine coolant temp sensor issue
  157. fuel pressure regulator location?
  158. Mobil 1 Turbo Diesel Truck 5W-40 oil?
  159. 1993 4runner timing tensioner
  160. High steer
  161. Installing a switch that disables traction controll on a 2001 toyota 4 runner SR5
  162. New to the toyota scene
  163. Newbie Question
  164. Toyota 4 Runner Head Gasket Recall
  165. trouble restarting when warm..
  166. LC Coils
  167. Can Someone walk me through Headgasket "issue"
  168. Headgaskets for dummies
  169. Thanks from a Newbie.
  170. 22 Point Inspection Results
  171. body swap info
  172. increase HP
  173. 2nd gen 4runner speaker sizes
  174. 20r Oil pressure drops once warm
  175. silly newbie question
  176. rattling 22re
  177. r to an re?
  178. Where to buy new 22r
  179. 2002 4runner sounds like there is an airplane taking off under hood!?!
  180. Salvage Yard Coils??
  181. how will my truck drive without regearing and 33's
  182. 94 toy
  183. Please help!! Need pics
  184. Radiator drain gasket?
  185. 92 Yota with a few questions / issues
  186. Mysterious alarm system component
  187. 79 carburator
  188. engine swap
  189. vacuum sound???
  190. ToyTech Coil Overs ???
  191. duel transfer cases
  192. 79 toyota 4sp or 5sp
  193. 90 Toy V6 4X4 temp problem
  194. what to do with this tire???
  195. Head Gasket Job #2 on 94 3VZE - 205K
  196. 1997 4runner 5 speed, Surge/Stutter
  197. 85' Pick up Hesitation, 22R
  198. how to stick quotes underneath signature
  199. transmission swap
  200. Question on oil filter??????
  201. How much is my truck worth?
  202. my 1985 pick up
  203. did i burn my clutch?
  204. sticky clutch 91 yota
  205. 86 4 runner tranny ?
  206. Somethings 'missing'; potential clutch problem??
  207. Narrowed Dana 44 vs. Toy 8"
  208. quick Q. with 33 do i need an aftermarket steering damper
  209. crankshaft oil seal housing
  210. 2001 Prerunner Rear main seal
  211. What the heck is this??
  212. My starter is fried.. need advice please
  213. 1989 pickup--Fan only has High??
  214. White Smoke
  215. not a newb but looking for advice....on a 82
  216. chevy spring swap - sky manufacturing kit???
  217. no check engine light?
  218. A couple of questions
  219. ARB air locker leaking
  220. '99 4runner lift
  221. 88 4runner
  222. few questions
  223. 1st gen 4runner REAR 1/4 panels METAL..
  224. Rough riding 4runner
  225. cant find the chopped 4runner thread
  226. First Yota wanna go with 33's can i see some pics
  227. NEED HELP FAST! Weekend with girlfriend at stake!!!
  228. turbo 4runner and i need...
  229. 89 4runner, remove ignition key cyl
  230. The OFFICIAL IFS "What size tire will fit" thread
  231. For those running wider tires on stock rims
  232. how much should i pay
  233. What engine can I put in my 95 4runner?
  234. Bad oil pump????
  235. Coils?
  236. front diff burning up
  237. 07 prerunner stereo help
  238. Front tires are angled funny.
  239. Turbo Motor Pics Please
  240. Another tire size question
  241. 22r red line
  242. help with codes
  243. fuel problem
  244. a ? about 3vze diagnostic codes
  245. Purchasing used 4runner guidelines
  246. What tranz gear oil???
  247. new toyota owner
  248. hello
  249. 88 toyota pick-up brake trouble
  250. get em or nah??
