Sponsored by: CARiD
chevy spring swap - sky manufacturing kit???
Old Jan 24, 2009 | 09:53 AM
beaterrig98's Avatar
Ok, here is another one of those chevy spring questions. I have searched the faq on pirate and here and have found nothing about the kit from sky manufacturing. So i was wondering what type of lift you should get from the kit using 2wd leaves. I only want 2 or three inches of lift, so would the chevy leaves and kit provide about that?
Old Jan 24, 2009 | 11:09 AM
LTrunner's Avatar
yes sir...the chevys give about 2-3 inches of lift, and sky's kit works great
Old Jan 24, 2009 | 01:34 PM
4banginRunner's Avatar
yes indeed, just wrapped my swap up today, with the sky kit...used 2500 Suburban springs tho, only using 3 leaves, no overload...probably around 3"s of lift
Old Feb 9, 2009 | 07:15 AM
dolemite's Avatar
do u have to remove the old bushings from the springs
Old Feb 9, 2009 | 07:18 AM
algranger's Avatar
i used springs from a half ton chev and i got about 5" of lift... guess i was a little more saggy than you guys.
sounds like you'll get three from stock but with sag working against you the height may vary
Old Feb 9, 2009 | 07:35 AM
904_runner's Avatar
Also, what rig is this going on?
Old Feb 9, 2009 | 05:06 PM
Turns out Burban springs aren't 63 inchers.... I figured out my shackle angle is wack due to the springs only being 60"....time to hit the junkyard for 63" mains I guess.
You dont have to, but in my springs the bolts were seized...so in the end I needed new bushings...and its cheaper to go polyurethane, stock bushings at Auto Zone and Advance Auto were 80 bucks for the set, I ended up paying 60 bucks on poly ones through Summit.
Old Feb 9, 2009 | 05:32 PM
bigt's Avatar
im gonna do this swap toa coil sprung runner.. there kit looks kinda worth it to me instead of fabbing everything..
but it doesnt include spring perches!!!
can i use ones for a toyota leafs spring on the chebbies?
Old Mar 1, 2009 | 02:51 PM
misterzee's Avatar
I just finished my Chebby spring swap yesterday, on my 87 4Runner. I got the SKY Kit. The Cheby springs I got from the salvage yard were in great shape, so I saved 75 and kept the stock bushings... its a job to get those stockers out anyhow!!
The only disappointment was SKY packed the wrong quantities/sizes of bolts, and some where too long. So, I had to waste time with a whack-saw, and trips to the hardware store to get the proper hardware.... you'd think they could....
Otherwise, the hardware provided in the kit: hangers, bushings, shackles are adequate.
I used springs from a 1500 series truck, and retained the stock chevy overload. That really keeps a lot of "push" with that setup, and it gave me 4-5" of lift, more than I wanted, so I'll be pulling that overload leaf OUT, and replacing it with something thinner.
The Chebbies are 3" wide, slightly wider than the stock Yota springs, so you will either have to grind a mm out of the inside of your U-bolts, or do like I did, get a new set made up. There goes another 50-100 bucks. And, your tailpipe will probably have to be slightly re-routed.
Old Mar 1, 2009 | 05:40 PM
Did you use the right ones in the right places? The kit does come with 1/2" and 9/16" bolts. I also had to drill out the front hanger to 9/16" to fit the bolt as said in the description on their site.
Flying91
45
Apr 11, 2024 04:39 PM
XtraCab
Apr 12, 2020 05:25 AM
jerusry
Oct 19, 2015 05:28 PM
wilbertd
Jul 6, 2015 07:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
