Sponsored by: CARiD
Oil Pressure Help
Old Feb 9, 2009 | 07:54 PM
beat86's Avatar
Oil Pressure Help
Okay so heres the story. (84 22r) I have a crappy mechanical gauge for oil pressure and the line burst the other day. I lost 3qts or so before i knew it . put it back together and every thing seems fine. After 10mins or so of driving when i stop (idle) my o.p. drops to like 5 psi! but as soon as i give it gas or go down the road it jumps right back up 40-50psi. It seems to run the same as it always has, no new ticks or knocks even when it reads 5 psi. Should i worry about this or do you think the gauge is screwy. any help guys thanks.
p.s. there is some air in the line too
Old Feb 9, 2009 | 08:00 PM
4Crawler's Avatar
What weight oil are you running? I find my '85/22RE pressure drops pretty low (basically to the bottom of the scale on the stock gauge) when the engine is warmed up at idle if I run anything lighter than 10W40. I usually run a 15W40 and the pressure stays in the normal range on the gauge. 22Rs do run pretty low oil pressure at idle, 4.3 psi min. per the FSM.
Old Feb 9, 2009 | 08:10 PM
beat86's Avatar
its 10-40 now. i had a quart of power punch in it before but i think it pissed it all out. Thanks for the info i feel a lil better now anyway. nice truck Btw
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
