Sponsored by: CARiD
vacuum sound???
Old Jan 30, 2009 | 10:09 AM
JimiJams's Avatar
vacuum sound???
Hey, I have a 3rd gen 4runner that's been making a vacuum sound for the past 2 years or so now.
Here's what happens (only when heat is on, I think the a/c too but I can't remember):
When I'm sitting idle I'll first hear a click sound coming from I think under the glove box. Sounds like a relay switch. Then the idle will go up about 100 rpms and there will be a vacuum sound coming from the same spot as the click sound. Then about 5-10 seconds later it'll click again and the vacuum will stop and the idle will go back down? This happens at almost every stop light. Anyone know what this is? Thanks for any help!
Old Jan 30, 2009 | 11:18 AM
DeathCougar's Avatar
That is perfectly normal. Its your AC pump turning on and off. The newer systems are designed to dry the air when the heat is turned on, so your windows defrost.
Old Jan 30, 2009 | 11:21 AM
JimiJams's Avatar
Ok thanks a lot Cougar, glad to hear it's normal! I must not have noticed the first few years I had it.
Old Jan 30, 2009 | 11:34 AM
If you watch your AC button, the light will click on too, indicating that the pump is on.
JNapolitano
Nov 14, 2019 07:46 PM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Aug 19, 2015 02:15 PM
viesail
Aug 17, 2015 08:39 PM
Sr5crawler
Jul 31, 2015 12:32 PM
