Sponsored by: CARiD
no check engine light?
Old Jan 23, 2009 | 10:14 PM
i206's Avatar
Unhappy no check engine light?
ok im new at this,this hole forum thing.ill tell about me later but i need some help first.
i have a 94 4runner 3.0 and a automatic,just rebuilt the motor and put it in,every things hooked up,but no check engine light,ive taken out and put in a haf dozen engine but nver this problem.i tern the key on but no check eng,it terns over but wont start?
ANY Ideas
Old Jan 23, 2009 | 10:27 PM
86tuning's Avatar
Either the main power to the ECM is not plugged in, or you may have a blow fuse, or perhaps a ground is not connected?
The main power for the ECM is usually black with red stripe.
Old Jan 24, 2009 | 07:15 AM
i206's Avatar
i checked all that.i got good power and good ground.i evan swapt in a comp that i know was good and the same thing happend.
Old Jan 24, 2009 | 08:19 AM
86tuning's Avatar
Check all your fuses again. There are two ignition circuits controlled by the ignition key. Perhaps one of the fuses is blown? No IGN+ to the ECM = won't power up.
I can't remember, and don't have a wiring diagram handy, but AM2 and IG1 IG2 I think....
Old Jan 24, 2009 | 07:38 PM
i206's Avatar
thanx for the help. everything was hooked up and after many hours of testing i found out it was the afm was bad.but thanx for the help
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
