View Full Version : Newbie Tech Section
- gauge cluster stopped working
- 93 4Runner stock gears to 5.29s
- newbee
- Questions on Center Console
- Drive Shaft Issues
- need bumper ideas
- Oil questions
- Diamond axle vs. rock assault? INPUT
- rear axle swap?
- Leaf springs which ones did you go with and why?
- Hypothetical question-Using low range on the road in 2WD?
- 3vze fuel line pressure hose/pipe
- Rear leaf question
- 5VZ-FE swap to 4 Cylinder Engine
- Differential ratio suggestions
- 75W90 vs Auto transmisson fluid -Transfer Case ???
- gears for 39.5" tires
- cam pulley hard to turn with wrench
- hydraulic pulley tensioner issue
- rear diff removal
- Marker lights into turn signals
- Bearing preload with replaced knuckle?
- Noob fuel mileage question
- Intake silencer removal mod question:
- 3.0 Motor Swap?
- 98 4runner parking brake cable removal issues
- For he who knows his axle service products...
- 1" bore mater cylinder
- Trouble after rebuild..
- Dana 44 axle info
- My diagnosis port cap is missing
- ? flipping 4runner onto 2h chassis OR 87 HJ60 drivetrain to 4runner
- I have a Vacum problem i think
- new truck year ideas
- Cannibalizing an 85 for SAS swap
- front U joints on drive shaft and Brakes
- Spring clips keep coming off of brake rotor?
- 96 4Runner timing belt broke
- Bed "droop"?
- tacoma refueling problems
- diesel to 93 yota none diesel
- mounting points on 88 4runner rollbar?
- 3.slow heads and cams
- Exhaust decisions . . .
- o/d shifting problems
- Can I swap 1985 4runner to a 1994 v6 rear?
- First-time spring swap; can I keep the stock hangers?
- 1983 toyota hilux prerunner build..need help!
- Wragnler bucket seats in a pickup...painful to install?
- Need some ideas on what kind of tire I should run
- Lift Kit 97 4Runner
- Drivin' a turd
- Long arm on a 4wd
- SR5 cluster
- help on seat belt clip female side
- Why Hi Steer?
- 4x4 question
- Conversion help 92 Toyota 2wd
- 95 4runner suspension
- 22R Timing with Weber 32/36 question
- w56 b swap for w56d
- Best deal on fender flares for 1995 pickup
- 22RE Burnt Valve??? Give me your thoughts
- 93' yota 3.0 v6 manual How good are these engines?
- 22re Rattle noise. Any help would be appreciated.
- Exhaust on my 79
- 96 tacoma 2.7 head torque spec
- 22R Failed Emissions
- 97 T4R front end grinding
- Doors???
- 14" ZUK spring on pickup-do I need a spring compressor?
- Truck bed trailer question
- How do I grease this u-joint [picture]?
- Should I purchase this Toyota? Swap frame or part-out?
- Offroad lights wiring
- 84 pickup, new owner.
- 85 Pickup running poorly
- new shocks for 88 22re pickup
- 91 ifs 3rd member ?
- 86 pickup 22re turbo hard to start
- Anyone installed a GFChip? Thinking about it.
- 94 4runner stopped running while driving
- 3.4 v6 rebuilt engine won't start!!!!
- rear window not working
- Leaking rear differential
- Need info on swap to 87 22r short block in a 83 22r 4X4
- Axle swap questions!
- Bent Axle?
- Is it okay to use lug centric wheels on hub centric wheel spacers?
- Steering Wont Return On Left Turns 92 4Runner
- Rock Crawler
- 95 22re fuel system pressure question
- 22re rebuilt smokes like a train
- Suspension and wheels
- oil changed my truck but ruin something else
- stock oil pressure gauge question
- Helpful info for the noob
- just curious, 37's w/ 4.88's 3.0 manual?
- Rear Prop Shaft Oil Seal (Remove T-Case housing???)
- Greetings and Salutations from the new guy.
- Where do I fill a W56 TRANSFER case with Gear Oil?
- 86 4-runner front wiper linkage
- tail lights, blinkers and reverse lights not working.
- suggestions for 1st gen 4runner motor swap?
- POR-15 Painting Frame
- Need help/advice on an '01 Tacoma build!!
- New Trekker Owner: What vacuum lines can I remove and still pass CA smog
- 5 speed side load transmission
- More flex out of IFS on the cheep?
- A340F to A340LE Pan swap?
- 3vze headgasket just rebuilt still smoke!!
- What kind of mgp are you getting???
- Coil Springs front and rear Pros/Cons for 86 pickup with SAS
- If you know the answer: 3VZ-E engines have 6 bolt flywheels, while most had 8 bolt fl
- 96 power antenna issues
- Torsion bar oops?
- newbie questions about sas
- wiring order (colors) for alternator plug
- Radio Static
- 22RE 4x4 Radiator/T-Stat Replacement W/ Pics!
- Suggested on-hand spare parts list for a '90 pickup
- lift on 89 p/u
- pickup cap specs
- spool in the rear?
- Window tinting on 86 truck??
- 88 pickup 22re weird dash light problem
- Opinion on BJ Spacers Please(yes I have searched the forum extensively)
- suspension question
- charge light in dash
- 86' 4Runner Possible Tire Clearance Issue?
- I want to put a holley on my 1987 22r?
- Rocker switch
- 22re swap into a '77 hilux 4x4
- Ride quality question - your opinion please
- 22r carburation issue
- Drive shaft swap question
- Rod bearings install
- 3.4 5 SPD problems
- SuperCharger and what else?
- Info on wrap window for camper shell
- Long Travel plus Drop Bracket
- fuel system and power loss
- Gas Tank Options
- '94 4Runner tailgate window regulator broken.
- Engine advice
- Bosal exhaust install
- getting the yota on the road again
- Rock Slider Length
- 95 4Runner 4x4 cruising problem
- Allergic to water?
- 1982 yota 4x4, but needs some work
- Tool Shopping
- front axle question? and a dumb one!!!!
- Hard to start when ambient temperature rises
- Interior coloring
- Which 1st Gen Runner Config Best to Build On?
- locking hubs not working
- rebuilt 22re
- towing with 33s
- Troubleshooting Help - 22R-E
- I want my rig in an offroad magazine. What do "I" need to do?
- New Guy from Hurley VA with 91 Pickup
- does any one have a chiltons or other 86 to 95
- Front shock recommendation for '87 4Runner?
- No power to fuel pump.
- Is there a Land Cruiser only forum?
- Rear Differential Question !!
- 3.0 dies when cold
- wealth of knowlege
- Lift question!
- Junkyard gold..!...?
- Cylinder 2 misfire
- 84 Pickup, Shorter Wheelbase.
- Someone tell me what lugs I need?
- Soft body mounts?
- Solenoid resistor plug bypass?
- oile presssure light comes on when braking
- 85 toyota pickup knock sensor location?
- Evolving into a REAL crawler
- Ultimate Fuel Economy Early 22R/20R Build Recipe
- 93 toyota pickup with 22re skips when first started
- where to find toyota parts
- Stock front spring hanger with lift springs?
- Completly stumped on my 85 issues. need help i have no clue
- New Header and muffler~
- HELP!!! Truck wont run!!!!
- engine light not giving codes
- Pressure release when I remove gas cap normal?
- my 86 toyota is making a grinding noise. I need some tech help please.
- can anybody tell me what model toyota pickup i got?
- motor swap question: 2wd 3.4 into a 4wd?
- Fixing chrome backing on off road lights
- Is this due to a lovely head gasket
- password reset for login for this site.
- used elocker opinions please
- Questions about replacing rotors
- got the yota back togather
- 89 4x4 question....chassis dimentions
- 3.0 swap for the 4.3 chevy
- is it lifted?
- what should i do about my motor
- How to tell if head gasket is bad for a 3vzfe
- Returning my inheritance to life
- Are spacers needed for brake upgrade on 95 Truck?
- Are bj spacers bad for ifs on 88 4runner?
- question about brake lines going to lspv
- front four link suspension
- what seats would fit a 1986 hilux
- axle shaft bearings
- Front end noise mystery!
- T.A.G. Multicarrier rear bumper- opinions?
- Source for parts?? 1990 4Runner 3.0 Waukesha, WI
- 1st gen p/u parts Sources?
- What size rear
- Rear Driveline Leakage!
- 88 22re cranks but no start.
- The V6 3.0L Question
- 3VZE head gasket
- Recommend Aftermarket Clutch Kit '92 Pickup
- WARN 8274 or 9.5cti - what to choose?
- Pressure plate help please
- NAPA (Bosal) replacement exhaust for '91 Pickup-$400-good deal?
- 7.5 IFS low pinion question
- 81 making noises in 4wd. I'm stumped.
- '88 pickup 4WD conversion
- What seal do I need to replace?
- Weber Vacuum Troubles
- Cylinder 3 misfire
- 1989 4runner Front/Rear/Transfer Case Questions
- V6 compatibility with 1990 4 cylinder
- Fixed the Starter, Still randomly wont Start
- Busted Pistons 1972 FJ40 F Engine
- metal to metal sound
- 86 Toyota door panel interchange??
- Picked up an 85 4Runner over the weekend
- valve tap
- best spark plugs for our trucks?
- Time to lift need info
- Codes 4,7 and 11 rough idle help needed!!
- 2003 Tundra SR5 150,000 mile maintenance
- Knock early model 3VSLO
- 2000 tacoma 4x4
- 87' Knuckles, Caliper, Hubs, fit a 91'?
- Help securing my 87 4runner
- Would this bumber fit on an 87
- Question on 3.0 to 3.4 swap
- My first car
- vacuum switch valve info
- 94 truck 22re, temp gauge not working? new owner
- Rough down shift into 1st upon stop
