Sponsored by: CARiD
Fixed the Starter, Still randomly wont Start
Old Feb 27, 2012 | 04:16 PM
Jeremy_C's Avatar
1990 Pickup 22re.... Had been having intermittent turn the key and "CLICK" no start. The tach will move up and down oddly, and the loud click can be heard but no crank. Replaced the brass connections on the starter, around the first of the year and it did it again yesterday.
I had thought it had something to do with a long trip and getting hot, but then other times on a cold start it will do it as well.
Any ideas?
Old Feb 27, 2012 | 04:30 PM
MP's4R's Avatar
Im not what is causing you problem for sure, but if you replaced imtrrnal parts, with no success, maybe its a bad/ loose ground or power lead. On a strange note though, mine would do the exact same thing especcially an cold mornings. I had a real spongy clutch so i replaced the master and slave. It fixed the clutch problem, and coincidentaly my starter has worked every time since. That was in devember.
Old Feb 27, 2012 | 04:34 PM
Jeremy_C's Avatar
I've had the starter checked, it checked good if those tests are trustworthy. My only guess is its a loose wire or bad connection somewhere...but my goodness there's barely enough room to see down in there where the wires are.
Old Mar 1, 2012 | 05:37 AM
speedfreek700's Avatar
my 4 runner does the same thing.im new to toyotas,is there a remote starter reley?
Old Mar 1, 2012 | 06:20 AM
snobdds's Avatar
Start with the basics. How is your battery, a low battery will not push enough current to the starter and do the click thing.
If it's your wiring, then your wires will get hot going to the starter. That will kind of tell you it's your wiring.
Clicking is good, that means your COR is getting power...
Old Mar 1, 2012 | 07:52 AM
RBX's Avatar
RBX
Same issue on my 92. My power cables were badly corroded down into the wire jacket. If I grabbed hold of the starter cable and jiggled it the truck would start. I replaced all the cables from the battery, starter and fuse me link. That fixed mine permanent.
Old Mar 1, 2012 | 08:00 AM
tditoyota's Avatar
I second this. I unfortunately bought a new starter for my 89 4runner, which did the trick for a while, but then it would start to do the same thing. I ended up replacing the ground and the positive cables, and bam, problem solved.
Old Mar 1, 2012 | 08:16 AM
Sensei's Avatar
If your cables check out ok then it's probably your solenoid. They do go bad as they see the influx of current for the starter motor.
Sounds like your relay is good per your explanation.
Old Mar 1, 2012 | 08:33 AM
4Crawler's Avatar
Do a little detective work to track down the source of the problem:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
And a couple of possible fixes if the problem is external to the starter:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Old Mar 2, 2012 | 12:26 AM
_RaStA_RoCkEt_'s Avatar
Listen to this guy,,,, he knows of what he speaks.
Old Mar 8, 2012 | 01:50 AM
Utah4Runner86's Avatar
Yup. After running the tests listed by 4crawler and not being able to isolate my intermittent start, I kludged up a "hot shot" from a ford starter relay and some wires, and haven't had any trouble since. But run those tests first.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Jnkml
Jul 6, 2015 01:20 PM
ptb12
Jul 5, 2015 01:49 PM
