Sponsored by: CARiD
7.5 IFS low pinion question
Old Feb 28, 2012 | 06:50 PM
MrJaron93's Avatar
This my seem like a very noobish question, but I didn't find any direct answer when i did a search.
Do i need reverse or standard gears in my 7.5 low pinion IFS diff?
From what i gather, if it is a low pinion it needs standard gears, and a high pinion has reverse gears. Correct?
I'm double checking because i don't want to accidentally buy the wrong gears and be screwed out of money when they won't work...
Old Feb 28, 2012 | 06:59 PM
87 Deathtrap's Avatar
High pinions are 8" and are, as far as I am aware, the only option that requires reverse cut gears. There is only one type of gear available for your front 7.5" ifs diff.
http://www.marlincrawler.com/differe.../toyota-75-ifs
Old Feb 28, 2012 | 07:04 PM
MrJaron93's Avatar
Okay. thank you!
I saw a reverse cut gear for a 7.5. But i just did a little more searching (after reading your post) and found out its for the 95-02 taco's.
Flying91
45
Apr 11, 2024 04:39 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
oldirtydirt
Feb 23, 2020 09:30 AM
scottyg486
Jul 19, 2015 05:34 PM
rushw
Jul 18, 2015 01:46 PM
