Sponsored by: CARiD
Pressure release when I remove gas cap normal?
Old Mar 6, 2012 | 08:50 PM
topdog63's Avatar
OK so I've notice ed that whenever I take my fuel cap off u get a long hiss from air pressure that has built up in the tank and its quite alot of air releasing. What causes this and is it anything I should be concerned about?
Old Mar 6, 2012 | 09:00 PM
drmix's Avatar
Im sure its normal mine does the same thing too. The fuel system has alot of pressure that builds up.
I wouldnt worry about it. I think that it would be better than not having any hiss at all meaning a possible leak somewhere
Old Mar 6, 2012 | 09:22 PM
BMcEL's Avatar
Normal.
[/THREAD]
Old Mar 6, 2012 | 09:37 PM
WHAHAHAJR's Avatar
I'm having the weirdest deja vu right now
ahhhh... figured out why
https://www.yotatech.com/forums/f120...on-lot-248643/
Old Mar 6, 2012 | 09:41 PM
thatsmyYOTA89's Avatar
like drmix said i would worry if it didnt. i cant remember a time that mine hasn't hissed when i took my cap off to fill up. it will release more air if you wait longer to fill up also ha
Old Mar 6, 2012 | 11:23 PM
zerokelvin's Avatar
cause: Fuel systems are designed with a sealed system in attempt to prevent fuel from being released into the atmosphere. As you drive your truck around.. using fuel->emptying the tank a bit-> this CAUSES a negative pressure in the gas tank. When you remove the cap (break the SEAL) air is being sucked (actually pushed, but we won't go into that) into the gas tank and you hear that "hiss". It is perfectly normal and it also lets you know your gas tank is sealed and working properly.
concerns: You should have ZERO concerns about this as the system is designed to function as you described Have a nice week
Old Mar 7, 2012 | 05:31 AM
topdog63's Avatar
Thanks guys
BMcEL I sent you a pm the other day. When you get a chance can you check it out and respond.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
horunner1x
Jul 10, 2015 06:33 AM
