Sponsored by: CARiD
suspension question
Old Mar 18, 2012 | 10:30 PM
itsbroke's Avatar
suspension question
Just throwing this out there. Here is the idea I like the its just not a fan of the torsion bar setup. Is anyone running or attempted to run a 3rd gen 4r front suspension in a 2nd gen. Let me know. Lift, no lift, to much work for little advancement in handling... You get the idea thanks for any info
Old Mar 19, 2012 | 03:29 AM
rattlewagon's Avatar
You can run coilovers with a TotalChaos or Blazeland LT front ends.
Old Mar 19, 2012 | 04:29 PM
itsbroke's Avatar
I would happily run either just don't have the funds. I can weld and fab that's kinda the idea I was going for. But if its not going to be any real benefit ill have to move on
Old Mar 19, 2012 | 05:27 PM
BMcEL's Avatar
Why coilovers? A lot of people will tell you the torsion bar setup is stronger. The overseas Hilux continued to use the torsion bar setup after the Tacoma came along. The US market has been tailored to ride comfort vs strength/off-road ability for quite some time now, hence the overseas trucks with factory solid front axles after '86.
Old Mar 19, 2012 | 07:19 PM
ThatGuy1295's Avatar
Ya, and a major disappointment to. Our own government to, hate it!!
Both setups use a-arms, you could throw coils in there. People have. The right coils and it will be a little softer then torsion bars. But still not gonna have any more travel. I don't see the need to switch just for handling.
Old Mar 19, 2012 | 07:44 PM
itsbroke's Avatar
Should have been a little more specific I do off road my truck. I was more or less asking if the newer 4runner setup is any more capable than the torsion bar set up. Looking for more travel don't realy want to switch to solid axle and it would be a long time before I could afford an LT setup
Old Mar 19, 2012 | 08:23 PM
BMcEL's Avatar
Throw some ball joint spacers on your existing setup and call it good until you go LT. I almost get a kick out of the added difficulty wheeling stock IFS.
Old Mar 19, 2012 | 08:26 PM
Then your F'd
Old Mar 19, 2012 | 08:27 PM
Jack n jill still needed the magic beans right?
Old Mar 19, 2012 | 09:02 PM
itsbroke's Avatar
Where I run the factory ifs actually works well. But thanks anyway guys
Old Mar 19, 2012 | 09:06 PM
BMcEL's Avatar
Ball joint spacers and low profile bump stops are about all you can do to increase the travel of your stock IFS on the cheap. Don't know what else to tell ya.
Old Mar 19, 2012 | 09:51 PM
itsbroke's Avatar
Thanks I was leaning that direction just saw a complete setup on a runner in the yard and thought I would throw it out there.
Old Mar 20, 2012 | 03:19 AM
He could run no bump stops!
Im kidding dont do that....
Old Mar 20, 2012 | 07:30 AM
BMcEL's Avatar
No bump stops + no front axles + sawzall = mucho flex.
Old Mar 20, 2012 | 08:11 AM
alanst100sr5's Avatar
Why doesnt my 97 t100 have coil overs is it because it has the torsion bars.
Old Mar 20, 2012 | 09:08 AM
BMcEL's Avatar
T100s use the same torsion bar setup as '86-'95 4runners & pickups.
nvdesertrunner
May 11, 2020 08:18 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
coffey50
Jul 28, 2015 10:55 AM
andrewtexas123
Jul 23, 2015 11:22 AM
Vargntucson
Jul 4, 2015 12:15 PM
