Sponsored by: CARiD
got the yota back togather
Old Mar 5, 2012 | 05:23 AM
Timothy Waller's Avatar
well i got my yota back togather but now it only will start with starting flud it has gas the fuel pump is working but it wont start only with starting flud does eneyone have and idele of want it is that is wrong please help me
Old Mar 5, 2012 | 05:25 AM
wii_tarded's Avatar
are your injectors working?
Old Mar 5, 2012 | 05:27 AM
yep it trys to start but it wont it will start with starting flud
Old Mar 5, 2012 | 05:42 AM
jammin962's Avatar
what repairs did you just finish? You sure you cycled the key enough times to let the fuel pump get the system fully primed back up? Mine took a lot of cycles and crankin before it built enough fuel pressure back up to fire and run pretty.
Old Mar 5, 2012 | 05:45 AM
it will run if u hold the key on but dies when u let go of it
Old Mar 5, 2012 | 05:47 AM
i changed the head on it it run before but now it wont
Old Mar 5, 2012 | 07:47 AM
Jasper 83's Avatar
Do you have the air intake hose hooked up? It wont run unless air is goin thru the airflow meter. If your spraying starting fluid in it it makes me think its not hooked up
Old Mar 26, 2012 | 09:17 AM
racerflea's Avatar
Jasper has a good point!!!
Old Mar 26, 2012 | 10:39 AM
it runs now but its flooding out and i`ve tryed everything to fix it
Old Mar 26, 2012 | 11:09 AM
racerflea's Avatar
When is it flooding like after romping or at idle
Old Mar 26, 2012 | 11:22 AM
all the time
Old Mar 26, 2012 | 11:30 AM
racerflea's Avatar
What all did u try and are u sure everything is grounded properly
Old Mar 26, 2012 | 02:28 PM
yes eveything is ground proprley
Old Mar 27, 2012 | 06:16 PM
racerflea's Avatar
Are ur plugs gapped right?
Old Mar 28, 2012 | 03:56 AM
Jasper 83's Avatar
When you say flooding, like itll barely run flooding or gas is comin out of places it shouldnt be flooding?
Old Mar 28, 2012 | 04:32 AM
Terrys87's Avatar
The way your post first started sounded exactly like my problem i fixed yesterday. I just got done trying to do a nice write up on how to fix it starting with easy to harder steps. It is on one of my last few post on my 86 build if you want to try a few of them steps.
Regency
20
Jan 3, 2020 07:43 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87blyota
Jul 10, 2015 04:31 AM
colinmil
Jul 6, 2015 04:03 PM
elwood73
Jul 5, 2015 07:07 AM
