PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. New exhaust
  2. Timing 89 22re comp cam
  3. Flimsy Interior Components
  4. 92 4runner not idling
  5. tinting factory treated windows
  6. How do I get the new CV joint in?
  7. Pull on Steering
  8. photoshop request! black rims on my 4Runner
  9. RTV silicone in place of carb gasket?
  10. Looking 4 a lift
  11. Need help 33x10.50R15 or 33x12.50R15 Photos?
  12. Timing problems
  13. poorly designed? or poorly installed? hose "?"
  14. SAS Questions
  15. Re-gear to 4.88s and I need suggestions $$$?
  16. Cruise Control Not Working
  17. Stock Torsion bar setting
  18. Hydrolocked my 3.4
  19. what welder is recommended for SAS
  20. 4.56 Gears
  21. To dangerous to drive after rough country install
  22. Ebrake light acting weird
  23. 85 pickup frame swap
  24. prepping for herculined side panels
  25. 88 body parts with 89-95
  26. Looking for wiring info for alarm install
  27. rear diff question
  28. What is this tube on top of my radiator?
  29. 22r,20r problems
  30. Help Identifying some electrical connectors.
  31. Body Lift Install help
  32. hard to keep idling every start up
  33. adjust front rake on '88?
  34. Where is a front diff breather located ?
  35. rearend of my truck is "spooling" up or "winding" up
  36. 2000 hood w/ scoop on 97
  37. 86 4runner reciever hitch
  38. NEWBIE Gears axles etc
  39. doubling the transfer case
  40. help with vacuum lines
  41. tire rubbing on passenger side
  42. I was going to use a paint sprayer, but now i'm having second thoughts.
  43. adding front diff drop
  44. Rear coil setup
  45. where to order a lock-right
  46. Rear lift blocks on 89 2wd
  47. engine rebuild help
  48. Need pic help!
  49. Pistons
  50. Shackle Angle Questions
  51. temp question
  52. Click Click Click Noise?!?! + lift?
  53. Is a 3.4 swap worth it?
  54. Newbie what knd of shocks and what lenght
  55. Newbie questions
  56. 87 toyota 4x4 full of rust
  57. Steering shaft compatibility
  58. Installing manual gages question
  59. Shackles, shackles, shackles!!!!!
  60. Brake size on base model vs sr5/limited
  61. Head Removal on a 22re engine ???
  62. new steering rack
  63. Signal Indicator Switch Problems
  64. wheel problems for a 93
  65. 85 Carb/timing help needed
  66. wilwood brake proportion valve problem
  67. Local mechenics?
  68. 89 22RE 4WD Issue
  69. Looking to find a skid plate to fit a Demello Offroad front subframe(?)
  70. Once and for all!!!-oil pan gasket or no oil pan gasket
  71. Future SAS gathering info
  72. 1st timer sas- 00' tacoma
  73. Is 4" to much lift
  74. 00 Limited w 265/75/16s?
  75. Multi-Mount Winch Bumpers for 3rd gen 4Runner
  76. A-Pillar Grab Handle
  77. can i swap transfer cases?
  78. have questions on new gauges
  79. Altimeter Info!
  80. 4runner radios interchangeable?
  81. what springs
  82. SAS questions
  83. What cabs will fit on '84?
  84. axles and gears?
  85. 22re Head
  86. Lowest SAS Possible?
  87. 2nd gen 4runner coolant leak
  88. Blown head gasket after 800 miles. Rock Products Good?
  89. OME lift 1992 single cab?
  90. Skidplate HELP!!!
  91. low oil pressure, high temp
  92. Crossover steering with moving axle foward?
  93. How can I test my ignition coil ?
  94. egr valve broken?
  95. Electrical Questions
  96. Weird wheel noise at highway speeds
  97. K&N on 22re
  98. Ideas on fab fenders flares to cover up my tires?
  99. Will new springs move the axle forward?
  100. NEWBIE Removing front rotors?
  101. NEWBIE am i missing something for my SAS?
  102. Header Flange?
  103. engine is running really weird
  104. Source for pinion shims
  105. What is this wire under my hood?
  106. will this radiator fit?
  107. What altitude do I need to do fuel upgrades for supercharger?
  108. BFG 33/9.5s?
  109. Seeking Recommendations for 3vze Timing Kit
  110. black aluminum wheels ???
  111. 4 Wheel Parts Denver any good?
  112. headlights clear corners bumper lights blinker lights for an 2002 4Runner
  113. Sag question
  114. quick power steering question
  115. stubborn bolt
  116. truck wont start just clicks
  117. help 22 re engine 91 toyota
  118. wont turn over
  119. Convert topshift w56 to a forward shift w56?
  120. About to buy head gasket set... question...
  121. lock right vs no slip vs detroit
  122. Shock Mounting option
  123. 31" tire option
  124. 22RE pushing coolant out the overflow, No bubbles
  125. Bad Miss In 99 4runner
  126. NEWBIE rear axle seal leaking
  127. help with lifts
  128. How to change spark plugs in 2004 4Runner V8
  129. 22re engine miss
  130. Rear axle oil seals
  131. Portuguese four runner sas..
  132. NEWBIE 88 22R not running so good.
  133. NEWBIE front shock bolt stuck in bracket
  134. NEWBIE needs help with transmission
  135. Bleeding (or just bypassing?) rear ABS
  136. NEWBIE needs a shock
  137. NEWBIE question about 2WD axles
  138. Spare Tire Rack?
  139. How much lift do shackles give?
  140. Flip Key DIY
  141. o2 senser free at dealer
  142. 22re rebuild
  143. Newbie needs some serious help
  144. NEWBIE 22RE Exhaust Diameter?
  145. 2wd Stock Shock Length
  146. NEWBIE radio and clock both stopped working - blown fuse? 02 sport
  147. Locker Question
  148. Increase highway speeds in a 1984 pickup 22R
  149. longer A-arms
  150. 92 toyota truck upgrade recommendations?
  151. what is the loudest tire?
  152. NEWBIE Best price on a 22re engine?
  153. T-100 Turbo?
  154. Buying used CVs a good idea?
  155. Driveshaft flange removal question
  156. tranny problems: shifting
  157. Newbie Bigger tires with 3.58 gears
  158. 22re timing with msd ignition box
  159. Newbie needs help with 3vze!
  160. injector service kits
  161. Will not idle
  162. ? On custom 3 link
  163. Trucks to reliable, mods !?
  164. core exchange?
  165. newbie - another cat theft victim needs help pls.
  166. Code #6 22re
  167. NEWBIE 2000 TACO full width
  168. tps resistance???
  169. vibration under 20mph
  170. Seedometer issue
  171. Need a new motor - what do you recommend?
  172. safety inspection-windshield on an '85
  173. 88 don't like any water
  174. Will an 82 22R fit an 89 transmission
  175. Best way to remove old gaskets safely?
  176. 5 speed swap: Will this fit?
  177. Toyota v6 power question????
  178. pinging on freeway up hill?: spark plug issue?
  179. budget high steer questions
  180. Power windows not working
  181. One Tricky Bolt. 93' T4R 3.0
  182. 92 p/u, backfires, stalls
  183. Which Transmission Do I Have?
  184. rear axle bearing replacement
  185. Air Rancho 4" Lift Kit? Need some quick advice...
  186. Replacing 3.0, List of other "new" parts needed
  187. Window won't open or close
  188. My shock broke woo hoo
  189. Trans. and trans. case fluid
  190. Timing chain jumped a tooth?
  191. Tundra Brakes Upgrade - Brakes are working!
  192. New Guy looking for BIG HELP ( 3.0 )
  193. Help with Fabtech Spindles
  194. What Weber for Cali Smog?
  195. cant find my auto tranny dipstick
  196. Stock roof-rack for spare
  197. Newbie needs the correct shocks
  198. Gearing/Diagnosis Help --tacoma
  199. TJ coils on 90 4runner
  200. should dashpot be depressable?
  201. W56 question
  202. Changing Belts on a 3vz
  203. Newbie - what makes my sunroof work?
  204. is there a difference in 22R blocks?
  205. 3rd gen 4runner rear wiper
  206. New to forum not sure where to start with 2WD
  207. what transmission with fit an '86 truck?
  208. installing performance accersories 3inch body lift on a 91
  209. factory paint for parts
  210. Newbie lifting my Toyota
  211. KZ-TE diesel conversion
  212. stock height
  213. heli-coil on head or tap hole?
  214. 22RE Surges After 20 minutes.
  215. wanting to paint my 81 pickup need help
  216. Weber 32/36,better than stock carb?
  217. Oil selection
  218. Replacing My T.P.S
  219. 3rd gen Runner fuel filter changeout
  220. need help drillin my gearbox
  221. Newbie help on Leaf Springs and Suspension
  222. 3.0 year interchange
  223. future lift thoughts
  224. Coolant Exploded, now car overheats badly?
  225. Transmission Trouble: '85 manual
  226. 98 4runner 5sp any issues or things to look at?
  227. T-case popping out of 4 low
  228. 88 4runner build/paint choice?
  229. New guy needs help 2rz into 84
  230. Fuel pump not on with key & engine turns but no start
  231. What to replace?
  232. Is it the rear pinion seal or something else?
  233. exhaust
  234. 1" spacers or suspension lift? 3rd gen 4runner
  235. Getting C-clip off axle?
  236. Rear bump stop busted off
  237. Recommended Mods
  238. New gear ratio for tacoma
  239. tps position affect idle at 2k rpm?
  240. overheating still!
  241. This Granny's still tryin'.
  242. Paint my bumper
  243. Transfer Case Hi/lo range selector gear play: how much play?
  244. Newbie looking for lift help
  245. front blinkers not blinking: 94 runner
  246. Wierd vibrating/fluttering sound upon acceleration
  247. Where the heck does this hose go???
  248. rear axle help: how to determine gear ratio
  249. SAS or Body swap?
  250. Newbie needs helping choosing the best generic auto parts store parts for 22RE
