Sponsored by: CARiD
What to replace?
Old May 17, 2010 | 08:23 AM
scoopthepoop's Avatar
What to replace?
I am the new owner of a 93 v6 4x4 pickup. I am trying to track down a little clanky sound in the drivers side front suspension.
So far I have eliminated the shocks and the sway bar as contibuting to this issue (shocks replaced, sway bar removed).
I just ordered new control arm bushings as well as new sway bar bushings and I plan to install those this coming weekend (control arm bushing replacement was a suggestion in another thread).
What I would like to know is what else is a "wear" item in the front suspension that so long as I have the truck on jacks and in pieces I should go ahead and replace?
Thanks
Old May 17, 2010 | 09:12 AM
PismoJoe's Avatar
Did you check the cv axles? They rattle if they are broken. (internal part)
Just check your bushings up front, they get worn. It wouldn't hurt to regrease your control arm bushings, etc even if they aren't worn.
Old May 17, 2010 | 09:29 AM
Haven't checked anything beyond the shocks and sway bar to this point. Will the CV axles rattle all the time, or only when the suspension flexes? Might be a good thing to replace anyway while I am in there. Thanks
Old May 17, 2010 | 10:26 AM
PismoJoe's Avatar
Usually the cv's will only make noticeable noise when you hit a bump or something like that
Old May 17, 2010 | 10:30 AM
graduatedpine's Avatar
And when you turn too right?
Old May 17, 2010 | 10:35 AM
PismoJoe's Avatar
Yes, though it wont be as noticeable. Tacomas and IFS toyota trucks in general have a tendency to "pivot" off of the brake caliper bolt. When you turn all the way in one direction, the bottom caliper bolt can make contact with the lower control arm. Don't confuse this popping noise with a broken CV, CV is more of a jiggling noise.
Old May 17, 2010 | 11:02 AM
Ok, cool
Old May 17, 2010 | 11:50 AM
I HATE THAT BOLT NOISE!!! You'd think that the tester of the vehicle in the 90s would have turned the wheel all the way.
I think I am going to replace the CVs anyway. It's not expensive and it being a '93, it can only make it better... unless I screw up the install
Thanks for the info, anything else I should replace while in there?
Old May 17, 2010 | 11:57 AM
PismoJoe's Avatar
Yeah, that noise is annoying, especially when you have long travel, the sound is even louder!
hmmmm not really, just check for oil leaks while your lookin in there....
Old May 18, 2010 | 07:46 AM
snoweater's Avatar
scoop: can you update this thread when you fix the noise, especially if it ISN'T your CV's...i have the same noise and my cv axle is pretty new on the driver's side! not sure what else it could be but it's def. in the left front area that is rattling going over bumps...
Old May 18, 2010 | 03:46 PM
swampfox's Avatar
have you checked the brake pads, to see if they might be missing anti rattle parts? i caught it late i should have said pads instead of shoes.
Old May 19, 2010 | 04:22 PM
Will do. I should be able to get to it this weekend. We'll see how it goes.
No, I haven't, but I will take a look at them when I have the front end apart.
Old May 22, 2010 | 03:11 PM
Turns out it was the control arm bushings. I replaced them with some urethane bushings and the clunking happens no more.
I still need to do some adjustments on the torsion bar, but otherwise I am happy with it.
It wasn't an easy DIY, that I will say for sure.
Old May 24, 2010 | 09:25 AM
snoweater's Avatar
Right, thanks! I had a feeling it was a bushing...didn't sound like anything broken, just something-worn-out type rattling.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
