PDA
View Full Version : Newbie Tech Section
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. Mechanic recommendation in connecticut 87 4runner
  2. fuel supply cuts out
  3. New OEM thermostat looks different
  4. 1986 Turbo Replacement: Help
  5. swapping alternator for internally regulated one 22r
  6. 85 4runner 22re hotstart misfire/rough idle after warm or long trip?
  7. 5VZ-FE Rocker Covers
  8. Weird electric issue 1 year after manual swap
  9. Weber Throttle Linkage Setup
  10. first time installing new head
  11. Engine Code 52 (Engine Knock Sensor)
  12. 22r iginition wiring bench test
  13. Is this normal? 22RE
  14. Where is rad4 runner
  15. '85 Pickup, driver door won't unlock
  16. Change Username?
  17. Camshaft noshaft
  18. Dry Compression/Wet Compression
  19. Mysterious Oil Loss
  20. My in ignition no dash lights no start no gauges
  21. Exhaust Ring?
  22. Axle identification
  23. 06 Highlander Hybrid Window Motor Q's
  24. Looking for a part
  25. Sealant/RTV on Intake Manifold Gasket?
  26. Workshop Manual
  27. Stripped Lower Manifold Threads
  28. Frame swap
  29. 1994 22re pickup click no start
  30. Abs code 1
  31. Clutch start cancel
  32. 1981 toyota pickup transmission
  33. And advice on water damage?
  34. Timing issues
  35. What's that
  36. Smog problem
  37. Detailed Wiring Diagram for 1976 Pickup SR5 20R
  38. 2021 does not like MP3/iPod
  39. New 22re owner valve tick
  40. Never have Yota’d before….
  41. Ever Seen This
  42. 1988 Heater selector clips
  43. 1994 pickup wont start
  44. Timing Question
  45. Carburator problem
  46. Low Compression Across All Cylinders
  47. Help! Too much oil in cylinder?
  48. Rear Wiper questions
  49. 1990 Toyota 4 runner automatic transmission problems
  50. Upgraded fr. disc brakes kit?
  51. Auto Lights
  52. Trying Bring my 85 back to life, need help!
  53. 1982 22r rough idle after warm start
  54. 87 toyota pickup click no crank can't find starter relay (video attached)
  55. Running high idle
  56. Yet another newbie tire/wheel question :)
  57. 1991 Toyota 4Runner fuel issue
  58. Timing chain cover won’t seal. Leaking coolant straight into oil pan
  59. 95 4runner 3.0 4wd won’t move.
  60. Happy July 4th
  61. Newb owner 95 4Runner
  62. 3zve distributor wiring issue
  63. 22RE pickup suspension question
  64. Tailgate Relay Box Question.
  65. CA Smog - '89 Pickup 4x4 w/ Aftermarket Air Intake
  66. 1994 toyota pickup lift question
  67. P0171!!! Losing my mind
  68. I need help with my truck
  69. Rust
  70. 2.2 diesel 2012 RAV4 DPF
  71. 1988 3VZE 4Runner CEL Question
  72. 89 1st gen camber maxed after 2” ball joint spacer
  73. Oil pressure gauge receiver swap between different models
  74. FJ40 Igniter
  75. Front Suspension/steering
  76. Taillight/ dash issue
  77. Help! Can’t get rid of vacuum leak 3 intake gaskets down
  78. Dammit is my rad officially toasted..?
  79. '93 4Runner 3.0 Auto Speedomete Goes In and Out Randomly
  80. Weber 32/36 choke cable linkage?
  81. Hello
  82. 93 T100 3VZ 2wd auto idles good, stalls before 2nd gear
  83. Help non-mechanic figure this out, please!
  84. In what direction does the rear differential crush gasket go ?
  85. Identify Engine
  86. Q about timing belt parts
  87. Start Relay Wiring - 91 2wd Pickup 22re
  88. Mk3 rear Door ‘strap’
  89. Which Fuel Pressure Test Kit for 22R-22re ?
  90. 1992 SR5 no 4x4
  91. Dumb question
  92. Sorry to be rude
  93. DIY digital fuel gauge
  94. 2.0L fusible link replacement
  95. Help A Newb With His Stupid Truck Please (Warm Start Issues)
  96. 2 issues on 1980 Pickup
  97. Help Diagnosing Starting Issue?
  98. Need 99 4runner sr5 ecu fed emissions
  99. How to Re-Add PCV System
  100. Black Hoses Sputtering Coolant
  101. 2015 tacoma whooping noise
  102. 1990 22RE surging idle advice needed
  103. 1996 Relay fuse
  104. 22R Distributer Timing ?
  105. '92 Toyota Pickup 22RE no spark
  106. 97 Camry 5sfe swap into a 91 Celica gt
  107. Hello from Colorado
  108. Hello
  109. 3rd Gen Pan-Hard Correction Kit (PCK) Welder
  110. 93 Toyota Pickup not reaching operating temp
  111. Vacuum Switching Valve. How hard is it to replace? 1986 22r Pickup
  112. 1993 Toyota pick up full width swap
  113. gas leak on 93 toyota
  114. P1228 and P0252 errors
  115. RAV4 HEV 2019 Autohold brake
  116. 3.4 Swap - 2001 Tacoma donor to 2000 4runner
  117. 3.4 Swap - 2001 Tacoma donor to 2000 4runner
  118. Vacuum Leak, rough idle, hard cold starts
  119. New Member, VIN info doesn't match the 'net
  120. 1993 pickup 22RE fuel gauge not working
  121. 1994 22RE Temp Gauge Not working
  122. A/C vapor?
  123. 1993 Toyota 4x4 pickup transmission question
  124. RN106 Hilux parts commonality
  125. 5 v swap no start
  126. What sub forum
  127. 93 pickup 3vz blowing EFI fuse
  128. Cylinder misfire
  129. 84 Toyota pick up w56 manual transmission
  130. 22re 1985, no start woes
  131. 90 3VZE Throttle body lower adjustment screw?
  132. auto trans problem
  133. 22re strange problem after start up
  134. Rough running 91' pickup.
  135. Get Ready to Saddle Up: Watch NFR Live Stream from Las Vegas Rodeo Online!
  136. Sports Events How To Watch Live Streaming Online Free
  137. 89 steering gear box rebuild
  138. Looking for 99 Rav4 3sfe wiring for ignitor not dizzy
  139. help with regearing for tires
  140. Farmer dragged 4Runner with tractor... Did he do damage?
  141. 1994 22re no start
  142. Code 42 on a 94 toyota pickup v6
  143. 2013 Tacoma 4x4 indicator light, low range issue
  144. Windshield Seal - Gap
  145. 1992 headlight
  146. 3.4l v6 2002 engine knock question
  147. Stock 2019 Toyota Tacoma sport eating through tires.
  148. Need help diagnosing idle problem!!
  149. 2006 4Runner TCM
  150. 1992 2nd Gen 22re suspension question…
  151. P/S rack fittings?
  152. Help setting to tdc
  153. Aw4 to a 22r motor
  154. 1987 pickup transmission relay issue
  155. Looking for engine repair manual for 22re.
  156. Threads for aftermarket temp sensor?
  157. Rough idle, what am I missing here?
  158. Fuel lines
  159. Are these timing guides original?
  160. Head shaved 20 thou. What gasket?
  161. What hose is this?
  162. 83 Pickup CA Smog Questions
  163. 22RE Rebuild Checklist
  164. What to look for when buying an older truck?
  165. Chasing a tap or knock
  166. Electrical help
  167. 85 Straight Axle Clicking
  168. 1st gen Taco e-locker switch
  169. 86 4x4 pickup starting problem
  170. Water infiltration
  171. 22re no start interment power to coil
  172. 79-83 Trailer Hitch
  173. Question
  174. 95 toyota 4 runner 3vze motor
  175. best spray paint supplier of manufacture colors
  176. wire hardness
  177. Weird overheating
  178. 96 big wireing problem or engine light problem
  179. 1992 4runner stock fender clearance measurement
  180. Planing a SAS with a Dana 44 on an 87 pickup, I need advice
  181. Anyone had car wires chewed by rodents, how did you solve it?
  182. What part is this?
  183. 2008 FJ cruiser P0332 knock sensor
  184. Fuel tank crossmember rusted out
  185. 80 pickup bed on 99 tacoma
  186. 80 pickup bed on 99 tacoma
  187. Oval Cover 2005 Taco Door Trim
  188. 85 Toyota Pickup 22R Keeps Blowing 80 Amp Fuse
  189. Regearing; For weight, not tires
  190. Fuel spraying out of sensor/valve on top of valve cover
  191. 1991 4runner accelerator cable part number?
  192. New Carb, idle issues
  193. 01 Tundra fixed antenna in 01 sequoia?
  194. Issues with Brakes or Clutch? Unsure.
  195. USDM trans in JDM 4runner
  196. No Ball Joint on Steering Stabilizer
  197. Front and rear diff oil change intervals
  198. Sudden gas smell in cabin, takes several cranks to start my 94 4runner
  199. Running rich!!! Looking for someone with unmolested 1990 Toyota pickup 22re
  200. 4sp & 5sp trannys interchangeable?
  201. Custom Audio Theories
  202. Stumped newbie
  203. What electrical item is this?
  204. 2RZ Carb with manifold Air Injection
  205. 93 3VZE Radiator fan always running
  206. Need advice on two tacomas I'm looking to buy.
  207. Help with Lug Nut
  208. 94 4Runner 3.0L 2x4 Stall after warmed up
  209. 03 4.7 tundra
  210. 1990 22re ran fine, parked, now cranks but no start
  211. Help with L52 trans!!!
  212. 1994 Toyota Pickup 22RE miss firing
  213. 88' Toyota Pickup, 22RE (break light, battery light, squealing belt and no brights)
  214. Brake squeal
  215. My 92 4wd ext cab pickup 3.0
  216. General observation
  217. Torque specs
  218. Another Newb 1993 4runner
  219. Transmission Fluid 1985 Pickup
  220. Coolant loss
  221. Transmission component identification
  222. Power steering pump into abs actuator
  223. Factory service manuals
  224. Please help, what is this electrical part in the motor bay?
  225. IFS lift kit needing update! Suggestions needed! 86 Pickup 4x4
  226. Box options for a 5th gen SR-5
  227. Seat back brackets for 88 4runner?
  228. Starter question for 95 Toyota pickup RWD v6 3.0
  229. Tcase ac tuator motor
  230. Preventing catastrophic failure, the head gasket
  231. 85 pickup starter wiring
  232. Question about an issue i am having
  233. Overheating, need help diagnosing.
  234. 2000 Hilux W56 to R156 swap
  235. Newbie Mistake on a 88 3vze Head Gasket
  236. Need help diagnosing 3VZE
  237. 1992 toyota a/c
  238. Speedometer roll back
  239. 1991 Toyota pickup 1Ton. Winnebago micro mini Warrior with. V6 3.0 liter.
  240. Heater is not working/ blows cool air only
  241. Transmission swap problem
  242. New on here have a 1993 toyota pickup 2WD, pulled the two screws on the afm and worse
  243. truck runs 5 minutes and then dies
  244. Duel case info please
  245. FJ60 Front and Rear Axle Help.
  246. 1994 Surf Diesel 3.0 RHD, already a "HALF BAKED" BUILD
  247. Need advice on 96 4Runner
  248. Intermittent loss of power/stalling
  249. Pre '84 5 speed swap
  250. IFS swap
