Sponsored by: CARiD
22r iginition wiring bench test
Old Sep 26, 2025 | 10:25 AM
milkman_14's Avatar
Hello, I am wanting to start my 22r after putting it back on the frame. I just want to run for a couple seconds to verify everything seems fine before I proceed. I was able to crank the starter, now I am ready to hook up the ignition. I want to double check that I hook +12V to this brown wire? Attached image of the wiring diagram I am looking at, current state of the project, and the brown wire I am referencing. Thank you!
Old Oct 2, 2025 | 03:30 PM
milkman_14's Avatar
Anyone?
Old Oct 3, 2025 | 02:48 AM
prcnctoyo's Avatar
I don't know about the 12v directly to the brown wire but would a pic of my wiring around the ignitor/coil help? I can get one posted this evening...
Old Oct 3, 2025 | 04:30 AM
milkman_14's Avatar
Sure it may help. I am not using a wiring harness at the moment but it will hopefully provide some clarity to how to wire.
Old Oct 3, 2025 | 01:38 PM
prcnctoyo's Avatar
I tested my coil recently and remembered a "brown wire" reference/test. It was the positive terminal on the coil. Though the wire looks more beige than brown. I pulled the bits below from the FSM. Hope this helps.
If you need a copy of an FSM check this link.
https://web.archive.org/web/20110102...ttora.com/FSM/
Wiring diagram for my '87.
Last edited by prcnctoyo; Oct 3, 2025 at 02:03 PM. Reason: added wiring diagram pic
Old Jan 5, 2026 | 06:47 AM
erfint4's Avatar
Tit-poute
Oct 12, 2024 06:31 PM
ericklofgren
Dec 6, 2023 05:49 PM
LordTurder
May 30, 2021 04:05 AM
irv
Jan 23, 2021 03:53 PM
austin GMC 2000
Engine Swaps
Apr 12, 2011 11:01 AM
