Engine Swaps Swapping an engine in your Toy, here is where to learn how
22r engine swap wiring
Old Feb 24, 2009 | 06:24 PM
austin GMC 2000's Avatar
Question 22r engine swap wiring
I am building a custom buggy, and have a 22r engine and a Manual transmission to go in it. I want it to be the simplest wiring i can have, no gauges or anything else just to start and run. I want push button start and a toggle switch to turn the ignition on and off, I have no idea how to do it, i don't know wiring at all and the only wiring diagram i could find is VERY complicated. I am a newbie and all help is very helpfull
Thanks Austin
Old Feb 24, 2009 | 07:48 PM
ozziesironmanoffroad's Avatar
just mount the engine and tranny, buy a harness from a boneyard, buy a manual ECU to go with it, and zip tie the harness to the buggy. simple as that.,
Old Jan 1, 2010 | 02:27 PM
mudwump's Avatar
Simple DIY harness to run
Actually, it's much simpler than that. Mount your driveline, positive battery to starter solenoid, negative battery to engine block and to frame.
Make another positive battery lead (10 gage or so) run from batt or solenoid B+ to your push-button then to the toggle switch.
From the toggle switch, run normal harness wire to the white or red wire on the igniter/coil (didn't say what year yer workin on) - the black wire will run a tach, if you want to later. You may want to add a connection from this to your choke and fuel solenoid, if equipped.
From the push button, run a fairly heavy gage wire to the spade terminal on the starter (just under the main B+ cable)
Flip the switch on and push the button, if you have gas in the carb it should run. I would invest (at least) in an aftermarket gauge trio to monitor temp, oil and amps.
Old Mar 22, 2010 | 07:33 AM
krelnydelnky's Avatar
does it matter if you dont hook up all of the vaccum lines on the stock carb on the 87 22r? like the smog ones?
Old Mar 22, 2010 | 07:51 AM
xxxtreme22r's Avatar
It does if you don't plug them up. haha.
Old Apr 26, 2010 | 07:14 AM
knottywolf1's Avatar
k where do i find info to swap my t0y0ta 3.0 for a 22re i have 4 22re engines from various years in my garage and 2 1993 pickups with bad 3.0s one is a 4x4 and other is a 2wh drv PLEASE HELP.
Old Apr 12, 2011 | 11:01 AM
bmaurice's Avatar
awsome walkthrough!!!
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
noahstancik
Jul 10, 2015 11:18 AM
thelifeadventure
Jul 2, 2015 03:09 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
TheManOutside
Jun 18, 2015 03:32 PM
