Sponsored by: CARiD
Need help diagnosing 3VZE
Old Feb 6, 2022 | 04:17 PM
OnlyDrivingToeyotas's Avatar
When I started my truck this morning the accessory belts were all seized, squealing, and started smoking. After taking all three of them off, the central pulley connecting to the fan clutch and the water pump was the one that was seized. The fan spins freely when I rotate it, but that pulley is completely locked. Is there an easy way of telling whether I need to replace the whole water pump or if I can get away with just the pulley?
Old Feb 6, 2022 | 05:41 PM
millball's Avatar
Not the water pump.
Water pump on 3vz is operated by the timing belt.
You need this::Mint/NOS genuine OEM Toyota Aisin/Koyo fan bracket, V6 3.0 3vze | eBay
Maybe...... There's one for early 3vz with spring type timing belt tensioner, and a different one for hydraulic type tensioner found in later 3vz models.
What year is your truck???
Old Feb 6, 2022 | 06:01 PM
Huh. The diagram I had pulled up marks that central pulley as being the water pump, but looking at parts, it's wrong. Thanks
It's a '90
Old Feb 6, 2022 | 06:05 PM
millball's Avatar
A '90 model 3vz is gonna take the early type fan bracket.
studawg66
Oct 26, 2019 06:26 AM
Coltsmith
Jan 1, 2019 02:01 PM
gotweasel6
Jun 27, 2014 11:43 AM
jrobertson4runnner
Dec 11, 2009 07:00 AM
austinmacry
Nov 9, 2009 04:12 PM
