PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. Diameter of exhaust 1989 4Runner
  2. Body lifts universal?
  3. maybe big electrical problem
  4. brake problems
  5. Suspension Questions (1993 Toyota 4Runner)
  6. 96 Tacoma 2.7 WONT START
  7. V6 calipers not all the same?
  8. My 4runner has sprung a leak
  9. 1990 4Runner
  10. Help me find a good m/t tire
  11. Antenna for 2nd gen. . .
  12. ifs locker or sas
  13. 1989 toyota 4runner rear suspension
  14. 84 pickup...ideas?
  15. just picked up a 95 tacoma with the 3rz and it has problems? need help
  16. Are all factory e-lockers the same?
  17. 5VZ-FE auto tranny question
  18. anyone used rear 2wd springs out of a dodge Dakota on a yota
  19. block vs aal, which one????
  20. 93 toyota t100 starting problems
  21. Alternative shift boots?
  22. Torque specs rotors/steering knuckle
  23. bent back to crank case pulley
  24. Horrible noises problem - 93 DLX
  25. Battery cable replacement on 6th Gen ('89) Pickup w/ 22RE.
  26. ECM diagram
  27. Toyota starting problems
  28. Coolant fitting (part # needed) for 94 22re
  29. Best all around tire for a daily driver
  30. Speedometer cable questions??
  31. 1997 toyota 4runner
  32. Clutch not working after replacement
  33. Aftermarket Steering Wheel Question
  34. 3rz leaks oil.
  35. 93 Toyota pick up has lost performance. 02 sensor became dislodged 4x4ing
  36. testing rear coils
  37. Question about cleaning before putting front hub/rotor back together.
  38. Driveline Squeak
  39. Coolant Information
  40. 1995 T100 radiator/coolant overflow problem
  41. Upgrading diffs...limited slip or no?
  42. 94 Pickup Lift question
  43. 98 4runner rear suspension: how close to this can I get?
  44. my baby is stalling and it isnt the MAF
  45. wheel spacer, Tire Size, trimming inquiry. 02 taco
  46. New truck, new issues
  47. Replacing a brake line
  48. lower ball joints 3rd gen
  49. Head gasket
  50. 94 Runner 3VZE rough idle, etc
  51. Front Winch Bumpers
  52. Failed smog/running rich: Is weber carb answer?
  53. Back to the future truck sfa or ifs?
  54. Leaf spring advice
  55. timing chain set??
  56. TOO HOT...need my a/c to stay on
  57. Brakes Lock up when vacuum line conected
  58. Few questions for a first time owner
  59. blocking plates?
  60. Identifying year model of motor?
  61. Best beach tires?
  62. Shock length VS Coil length
  63. driveshaft question
  64. Vibration at 40-60 mph
  65. No solid axle?
  66. Weigh in on SAS and gears
  67. Need leaf spring help
  68. '87 Pickup - Adding AC - Is it worth it?
  69. compatibility with fabtech lift and bumper/skid plate?
  70. cylinder head gasket sealant
  71. cylinder head intake studs
  72. 22R-E Rattle Noise - Help?
  73. new off road tire selection
  74. 2002 Toyota Sequoia Overheating when idle
  75. 1985 or 1995
  76. Shackle Bushing Question
  77. suspension updgrade
  78. 2002 4 Runner Issue..
  79. 86 4runner sas using 85 4runner donor car
  80. new to me 91 4x4
  81. gear oil on rim
  82. 1985 4runner power steering pump
  83. How do i find my lug pattern?
  84. Brakes upgrade for 96 4runner
  85. 4.56 Third Member
  86. manual to auto
  87. 85 4runner front shackle rubbing frame
  88. 5.3l Swap into 93 Pickup questions and intentions
  89. What can I buy for my truck?
  90. Igniter wiring?
  91. 84 4x4 has fire and fuel but wont crank
  92. '87 4x4 tailgate (&other parts) cross fit?
  93. 95 3VZE chug on acceleration?
  94. Brake line fittings, adapting to aftermarket Prop valve.
  95. Brand new cylinder head break in proceedure
  96. Front and Rear Axle Ratio help!
  97. 3rd gen 4runner 3" body lift
  98. exhaust seems hot
  99. Can I weld my front diff?
  100. Radiator dual core upgrade
  101. Weber carbs
  102. fast idle issues 3.0
  103. 3rd gen wheels on a 1st gen w/ straight axle
  104. Fiberglass vs Rocks
  105. Oem lightswitch hookup for PIAA lights
  106. Speedometer
  107. 1985 Toyota Diesel Pickup Bed Removal?
  108. 5 speed transmission questions
  109. removing emissions system
  110. 1985 22r 5spd
  111. 97 4Runner Lift Recommendations on a buget
  112. New Rebuild gone bad! Keith Black Pistons..
  113. output/tail shaft lose on 84 4x4.
  114. Oil overfill from jiffy lube!! Help and advice
  115. 99 4Runner Upper Ball Joint Problem
  116. Gas Mileage
  117. Whats the name of the shop in oregon does 3.4 swap?
  118. Got my first Toyota! Tips on a new exhaust?
  119. vacuum problem 3.0
  120. Alternator upgrades?
  121. Locking Rear Differential Options
  122. 1992 22RE w/ EFI bogs down (momentarily) when applying brakes.
  123. Best shocks/suspension for 98 4runner 2.7l RWD"?
  124. A couple ?'s about brakes & dash screws
  125. What do these aisin hubs FIT??
  126. 2" higher on the left side?
  127. 92 Toyota PU 22re 4wd; hard vibration when above 30mph
  128. Oil sensor thread counts and size??? HELP
  129. I need a speaker list for a 94 4runner
  130. Yota cranks but not starting. Suggestions welcome.
  131. Bed Replacement
  132. 22r wiring question
  133. HELP PLEASE! 86 yota w/ 94 trans
  134. New to forum
  135. Front fender body seam
  136. faulty mastercylinder?
  137. Engine Under Cover - stupid question
  138. steel brake line install
  139. tube or plate bumper?
  140. Axle Interchange
  141. Gasket material opinions
  142. EGR temp sensor 94 pickup code 71
  143. 99 4runner 3.4 stalls like out of gas but isn't
  144. auto vs manual
  145. 92 4runner v6 auto incline problem
  146. 92 4runner pesky problem
  147. sas and lift question about shocks?
  148. Removing lift from 96 tacoma
  149. 22re hesitation
  150. '91 Pickup V6 4x4 Fuel Leak
  151. 89 toyota pickup V6 want to lift
  152. After Compression Test, Code 12
  153. Lower A arm replacement
  154. Best Ball Joints for $ and other IFS ? Help a newbie out
  155. best place to get gear sets
  156. Help ID a rubber o-ring found resting on lower suspension arm.
  157. rod bearings
  158. Is it okay?
  159. what it this and how can i get rid of it
  160. 02 tacoma drivers window
  161. Cat/O2 Question
  162. 93 4runner new engine vs. rebuild
  163. Wont Start 90m 4runner
  164. Timng chain guides gone, what to do?
  165. 86 4runner start problems
  166. 3vze Code 11
  167. hard to crank by hand
  168. 5" front leafs what size shocks and hoops?
  169. to Zuk, or not to Zuk....
  170. intermitent engine light issues while driving
  171. What wheels need spacers for vented brake swap? (survey)
  172. Question about anti-seize on brake fittings
  173. Idler Arm
  174. Which wheels should i get
  175. cheap place for clutch and tranny rebuild kit
  176. 95 4runner needs new engine?
  177. Problems with my clutch release bearing!
  178. first gen 4runner half top help
  179. scared the crap outta me
  180. Lifted 4runner concerns
  181. starter crank bolt breaking w/ partial disassembly
  182. 3rd gen t4r water drainage
  183. trans mounting bolt grade
  184. 8" or 8.8" rear diff
  185. Air conditioner install
  186. 1995 3.0 oil leak on top of the block
  187. 85 Fully Trussed Axle Price ?
  188. 22re/22rte injectors
  189. Auto tranny oil
  190. Transmission swap for 86 1 ton truck
  191. 22R Weber Carb install just a couple Q's!
  192. 4x4 bed verses 2x4
  193. Pro Comp ES3000 vs. Skyjacker Hydro 7000
  194. tacoma e locker
  195. fun day with new 4runner
  196. pickup jerks, lurches in idle
  197. 99 runner front end clunk
  198. M/T Cruise Control - 94 22re
  199. 91 toyota pickup v6 to 22re engine swap
  200. Rear WB parts check?
  201. toyota with horrible idle surge
  202. my gas gauge stopped working?
  203. Pedal stays down when bleeding slave?
  204. need some advice on lifting my truck
  205. Paint Job Basics
  206. 1990 Toyota 3.0 engnie replacement question.
  207. 95.5 Taco TJM to 94' Pickup?
  208. 3rd Gen 4runner Rearview Mirror Upgrade!
  209. 1993 4x4 shock bolt size?
  210. ATT: Canadian Members question about parts
  211. driving dual cases for dummies?
  212. Difference Between Chrome & Plastic Bumpers?
  213. Starting issue - ever hear of this?
  214. Rough Country Vs Superlift
  215. 1992 22RE leaking coolant into new head.
  216. 2001 4runner: prepping the water pump mating surface
  217. Noisy rear end in deceleration
  218. Oil Smells Like Gas
  219. wheel and tire compatability please
  220. Weber 32/36 DGV gasket/jet kits? 20r settings
  221. Idle and high speed noise problem
  222. leak in front,power steering gear box??
  223. Spring shackles
  224. Help with my seats please!
  225. Manual transmission swap
  226. front lockright driving question?
  227. Hub swap question
  228. Engine/Exhaust ticking mystery??
  229. 89 toyota stock rear end gearing
  230. dumb question... random switch?
  231. oil pressure on start up question
  232. I need help on choosing the lift kit on my 98 4runner
  233. 350 vs. 3.4
  234. 1999 4R Limited clicking and popping noise!!!
  235. 3.0 won't start
  236. Shock question
  237. 93 4Runner V6 4x4 Auto VSS road block
  238. Question about tire and rim size for 99 4runner
  239. Possible to contain messy oil leak?
  240. stuck gas pedal
  241. Problems bleeding brakes 94 SR5
  242. broken speed sensor bolt heads
  243. 86 4runner starts ok but starts horribly after running for awhile
  244. w50 parts
  245. Wheel bearings - check my work?
  246. Build up or Rebuild?
  247. 94 yoda sas questions
  248. 2Gen 4runner fuel tank.
  249. Rebuilding birfield question
  250. bleeding the brakes
