Sponsored by: CARiD
front lockright driving question?
Old Apr 26, 2012 | 08:52 PM
runs-on-4's Avatar
picked up a lockright of craigslist awhile ago and installed it in my 410 front diff. i heard it was suppose to be a pain to drive especially on the street but i can sometimes almost not turn at all . when i lift the truck off the ground and spin one tire its locks unlike my old spartin where it would let one tire spin faster then the other and you could here it click.. is there something wrong with my current front locker if its not unlocking ever or is that just how they are.
i ask this because im about to put in my 488 front diff and plan on using this locker if it works properly
Old Apr 26, 2012 | 08:53 PM
runs-on-4's Avatar
not that it makes a diffence but im not sure if its a lock right or an aussie
Old Apr 27, 2012 | 06:04 AM
stngllhm's Avatar
I know my lock right would rarely release on corners. Only when I would coast thru a corner would it release the out side wheel but that was on the rear. I was lead to believe that was normal I was always told there is a reason they are the cheapest.
Old Apr 27, 2012 | 08:03 AM
justin_4runner's Avatar
make it easy on ur self. get some disconnects for the front so it doesn't lock on u as u are turning corners. problem solved.
Old Apr 27, 2012 | 03:55 PM
runs-on-4's Avatar
waht do you mean dissconnects. im talking about when i have it in 4wd on dry pavement it steers sometimes but doesnt release dirt its fine.
Old Apr 27, 2012 | 06:28 PM
oh when its not in 4wd getting the factory locking hubs so u can unlock them and im not sure why u would want it locked on the street even in 4wd, i would just lock in one of the hubs and drive like that unless on snow. and even on snow it will let the front slip.
Old Apr 28, 2012 | 07:49 AM
85TurboRunner's Avatar
You're driving it on dry pavement while in 4WD and trying to turn?
Don't do that. Causes extreme binding in the drivetrain, especially with lockers. You will break stuff quickly.
Old Apr 28, 2012 | 11:50 AM
zachidds's Avatar
Old May 8, 2012 | 03:21 PM
runs-on-4's Avatar
so to update . before it on pavement. it would barely turn.. on dirt it was easier... no on pavement. it turns with a little resistance and like normal on dirt.
yes i know its not good to even try it on pavement. but i guess something was put in wrong before. cause its a lot better now with teh new gears
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
