Sponsored by: CARiD
block vs aal, which one????
Old Jun 15, 2012 | 07:07 PM
87yotaaa's Avatar
im planning on lifting my 87, im getting a 2in bj spacer with diff drop, and sway bar drop, and 2 new shocks, but i dont know what for back, i may just leave it, whats yalls opinion??
Old Jun 15, 2012 | 07:19 PM
Teuf's Avatar
AAL, do not do blocks.......... In the end its the best choice, good luck. And welcome.
Old Jun 15, 2012 | 07:59 PM
James Woods's Avatar
^X2, its not the best choice, but the best of the two is what I think Teuf meant to say.
Old Jun 17, 2012 | 10:54 AM
87yotaaa's Avatar
thank yall both, ill let you know how it turns out
Old Jun 17, 2012 | 11:11 AM
runs-on-4's Avatar
could get longer shackles also
Old Jun 18, 2012 | 10:40 AM
93Xtra-Cab's Avatar
Longer shackles would be better than both the blocks and the AAL. AALs are stiff and W your leaf springs after a while. Blocks cause axle wrap and look tacky. Longer shackles are the best thing to do other than buying brand new lift springs. The only downside is that if you go too long, your driveline angles will suffer causing vibrations from your U-joints. They do, however, make alignment shims to go between your leaf springs and rear axle to correct your driveline angles. Take a look at 4Crawlers website. You'll be amazed at the quantity of information.
Old Jun 18, 2012 | 11:37 AM
87yotaaa's Avatar
or should i just get a 2in body lift,? my truck just has 31s and i just was i bit more gap between tires and fenders
Old Jun 18, 2012 | 12:18 PM
rattlewagon's Avatar
A body lift wont help your suspension. Youll still have a saggy butt.
Old Jun 18, 2012 | 12:21 PM
Outsane's Avatar
Or Zuk Mod
Old Jun 18, 2012 | 01:01 PM
yoder519's Avatar
i have a 2in AAL to match my BJ spacers and it sets level. After a few years though, the add a leaf has twisted my springs a little because it started to slide in the pack. Im about to do a SAS and gonna run stock leaves out back with a 3in block. Then after I break those springs, Ill buy aftermarkets. Hope this helps
Old Jun 18, 2012 | 01:52 PM
cman1's Avatar
x2 on zuk mod.
Old Jun 18, 2012 | 03:05 PM
Swimmerboy2112's Avatar
People will say that the AAL's will cause the springs to fall apart and they will say that the AAL will really limit flex.
Regarding the falling apart springs, 2 years and 50,000mi later they are still just like the day I put them in.
As far as the flex goes, you be the judge;
Old Jun 18, 2012 | 07:40 PM
87yotaaa's Avatar
surprisingly enough, it doesnt sag, it sits pretty level now, i just want more space in fenders and im kinda on a budget still being in highschool, and this is the best pic i got and the back end is slightly down hill, no sag
Old Jun 19, 2012 | 05:11 AM
ThatGuy1295's Avatar
It does look like it leans to towards the passenger side. Could just be how its parked.
Old Jun 22, 2012 | 10:20 AM
87yotaaa's Avatar
hah its the pic!
Old Jun 22, 2012 | 10:41 AM
bob200587's Avatar
Originally Posted by Outsane
Or Zuk Mod
I came here to post this.
I ran AAL for a couple of years. Then one of the added leaf springs broke, separated from the rest of the pack and shredded the sidewall on my tire. So I had to take them out and go back to butt sag.
I'm going to do the Zuk mod this time around.
Old Jun 24, 2012 | 09:42 PM
TrikeKid's Avatar
There's nothing wrong with blocks so long as they're made of steel. THOUSANDS of blocks installed on trucks from the factory so they obviously aren't that horrible. Long shackles are hard on springs and mess with your pinion angle. Also the longer a shackle gets, the more beef has to be built into it. Nothing wrong with any of the three methods IMO. A properly assembled pack with an add a leaf is just as safe as any other spring too. But yeah, you get cheap spring pins, use a bolt instead of a pin, under or over tighten them so they break and yeah, it'll cause ya problems.
Old Jun 25, 2012 | 05:48 AM
westjohns yota's Avatar
ive ran a block on all 3 of my rigs, beat the snot out of them, and havent broke a thing or had any problems IMO....
mistershmi
Jan 5, 2016 11:07 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
moparbay
Oct 6, 2015 09:24 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
