Sponsored by: CARiD
Spring shackles
Old Apr 27, 2012 | 12:18 PM
Robsteeler66's Avatar
Spring shackles
Hi guys, I tried searching and I can't find anything. I see all the lift shackles, but I just want stock sized replacements. Is the dealer the only one who has them? I finally found stock length leaf springs and I want to replaced the rusted up shackles at the same time.
Old Apr 27, 2012 | 01:24 PM
wyoming9's Avatar
Red face
Toyota sells a complete shackle kit. one for each side.
The price is not all that bad you get all the hardware and bushings.
I use them all the time
Old Apr 27, 2012 | 04:22 PM
Thanks I guess I'll check with the dealer.
Old Apr 30, 2012 | 09:41 AM
highonpottery's Avatar
stock is a 3.5" shackle, eye to eye. if you need lift, it's 2" longer shackle for 1" lift height.
you're most likely going to pay through the nose if you go to dealer - definitely get a superior aftermarket shackle for less $, that has poly bushings and greasable pins. google will show several places to buy them.
Old May 1, 2012 | 08:19 PM
Thanks, I didn't want a lift though. I was looking at my rusted one and when I hit it with a hammer it seems pretty solid, so I might soak it in some rust remover and see if I can reuse it.
Old May 2, 2012 | 09:45 AM
you can definitely reuse them if still solidly intact. probably want new bushings though.
BudBuilt Shackles
4Crawler Shackles
Dave'z Shackles
you can also buy longer shackles and drill a new hole if you want them shorter - or even just buy new shackle bolts and drill some plate steel.
live4soccer7
May 11, 2016 06:52 PM
ktm192k
Oct 1, 2015 08:47 AM
Brodetski
Sep 30, 2015 11:50 PM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
