PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. On blocks - harmful or not?
  2. just wondering
  3. 93 22re idle problems - now won't start
  4. What kind of axles work best for more width?
  5. Traction bar is bent. what to do?
  6. 3rd Gen 4runner feels like a boat at high seas
  7. This fit on '96 4runner?
  8. ODO/SPEEDO/drivetrain issues with tire swap
  9. Help smoke....
  10. Build Plans
  11. New to the forum could use some help.
  12. Help with Rear locker
  13. smog check p0505 error
  14. What do you call this?
  15. 1990 4rnr waterpump/timing kit pricing
  16. Spark Plug Wiring on '04 Tacoma?
  17. replace lower ball joints
  18. w58 question, not sure were 2 post
  19. Key won't turn, steering wheel stuck - help!
  20. 91 yota pickup -- Accelerator pedal hard to push
  21. 86 4x4 22re ex cab
  22. Lift help
  23. 99 4runner springs, whats the part number?
  24. new here and have a question
  25. Question about lockers
  26. rear end trouble
  27. IFS to SAS
  28. need help diagnosing rear end noise 91 extended cab
  29. 4 cylinder Highlander
  30. Need Help
  31. power stering
  32. Going to buy an ifs lift kit soon. Any tips?
  33. ?What Parts? Solid Axles
  34. 86 Toyota Pickup 22R
  35. back window not rolling down.
  36. 98 4 Runner Back Window
  37. Cold Start Stuck on?
  38. Lifting a 88 4-Runner
  39. Dropping '82 motor in '86 truck?
  40. 04 tacoma straight axle or ifs?
  41. Power steering belt 86 runner
  42. Do I need to replace this injector, (93 3vze)
  43. shackle/leaf spring/?
  44. new to all this
  45. need advice on sas suspension
  46. need help with sas swap
  47. Need Tranny
  48. brush guard compatibility
  49. How off-road capable are 1st Gen 4Runners with IFS?
  50. Best year front axle for SAS
  51. lifting a '99 with r16's-coil question
  52. Replacement 5 speed trans ????
  53. Wanting to lift 94 2wd pickup
  54. how bad will it rob power
  55. will this bumper fit?
  56. Bolt pattern
  57. gears 4.88 or 5.29
  58. 1985 4Runner cup holders
  59. head bolts and new head
  60. how to put disc brakes on 2wdtoyota truck
  61. cheapest way to lift my 4runner
  62. ecu reprogramming
  63. t/c question
  64. first lift
  65. 92 4runner newbie
  66. chirping noise aft hg replacement
  67. welding in a westin brush guard and a winch
  68. noob ifs question
  69. 88 4runner beater..got advice?
  70. stupid question, changing displays from metric to standard
  71. fj80 springs and spacers on a '99 4runner-whats the ride like?
  72. 4 Runner Chrome Lower Valance?
  73. What PSi????
  74. Newbie with lots of questions about my 86 4x4
  75. Head Unit mounting problems..
  76. missing link
  77. Spent the last hour searching... Cant find answer
  78. Which diffs to use for my '86?
  79. Question: Do my own exhaust?
  80. leaf springs
  81. NoOb SAS attempt..
  82. Lift on a Budget
  83. 5 speed tranny
  84. Not as important as previous ? ,but
  85. HELP Please!!! Bedliner / Gravel Guard???
  86. tire lean on an 86 pickup
  87. '93 Tranny Issues
  88. v8 swap
  89. Need Some Help
  90. Advice on axle swap!!!?
  91. HELP! Washer cleans one side of windshield only!
  92. Questions From a Super Nooob..
  93. Put New clutch in my 85 toyo somthing WAY wrong!
  94. New Guy with fuel delievery question
  95. 33x12.5 on a 93 4runner
  96. inboard axle retention?
  97. I need a cheap lift for my 96 runner
  98. 22r dimensions
  99. 2 or 3in body lift
  100. 2000 Sienna Timing Belt Replacement
  101. Very wierd question.
  102. manual hubs
  103. Lift help
  104. How much lift do i need?
  105. Hello from S.O. cal
  106. Ring gear pattern?
  107. M/T ECU and A/T ECU ?
  108. sas on 3rd gen...
  109. How big can i go?
  110. 22re asembly tips
  111. Want to go bigger
  112. fender trimming on 3rd gen?
  113. 91 4runner rear diff
  114. need new headlights
  115. PAIR Reed System Removal
  116. swapping wheels?
  117. Intimidated...
  118. suspension help
  119. Search button not helping... Help me re-gear to 5.29's!!!
  120. straight axle conversion
  121. IFS gearing question... help
  122. is it the same chassis
  123. Rear differential oil??
  124. Starting Problem
  125. hub problems
  126. which fluid for tranny,transfer case,axle
  127. whats the stock gearing for a 89 pickup
  128. FOUND SOME 488s!!
  129. Headgasket Shim
  130. Quick 2.7 Tacoma TPS question
  131. what kind of fluid for axle,tanny,transfer case
  132. SAS on 86 4runner
  133. Help with a lift.........
  134. 88 V6 starting issue
  135. lets talk more power cheap
  136. sway bar or no sway bar?
  137. 2TR-FE ECU Pinout diagram
  138. whats involved in changing rotors on a 94 4-runner sr5?
  139. new here
  140. 1988 22re EFI has starting issues
  141. Hello, new here, looking for advice....
  142. wheel spacers
  143. Aloha All
  144. 1988 4runner lift kits?
  145. Engine Rebuild Kit
  146. how big of tires can i go without changin gears?
  147. 22re crate
  148. 1.5 inch lift for 1999 Limited 2wd
  149. quick questions for stock lift with tire upgrade
  150. lock-right locker
  151. Tool Box?
  152. Cat only?
  153. questions about a sas??? please help!
  154. Pulling front axles on 2008 Tundra
  155. pre runner
  156. 4 Wheel Drive Hi
  157. i need help with head
  158. where is are those holes
  159. 1989 Toyota Truck Leaking frenzie!!
  160. real quick stupid question
  161. 22r to 20r
  162. Will these wheels fit my 95 4Runner?
  163. new clutch
  164. 94 Pickup Grounding/relay Issues?
  165. 92 v6 sr5 toyota 4 runner mods
  166. Buying parts online
  167. Help on Picking the Right OLD MAN EMU coil springs
  168. Issue with my 4runner
  169. Replacing rear window relay
  170. Where can i find a 2in body lift
  171. Question about welded diffs
  172. Fuse Box
  173. I need Help with this!
  174. just purchased a 1987 toyota 4x4
  175. ANY Advise?
  176. shocks location "85 pickup"
  177. Bad ignition switch
  178. Engine squeal
  179. Need help, code 11 and hard to start..
  180. shackel angle bad?
  181. is the link important
  182. is it the same
  183. help! transmission problems?
  184. 87' Already Bought 3" Bl, Want Rear Leafs... What SL to buy?
  185. Help me with ideas and got some info
  186. homemade intake systems?
  187. 89 4runner Rear winch bumper
  188. Interchangeability
  189. 92 Transmission swap Auto to 5 speed
  190. Pinion oil seal replacement
  191. timing sprocket
  192. My 1993 toyota 4runner 4wd wont engage!!??!
  193. URGENT and need the help...
  194. 1988 22RE Headgasket replacement gone off course...
  195. lift
  196. headers?
  197. Got stuck in mud..NEED HELP
  198. 93 4runner rear sag, what coils?!
  199. 92 clutch issue
  200. something in gas tank...
  201. Will suzuki lock outs work with my TACO
  202. Performance loss going from 225s to 33s?
  203. Transfer Case fluid question
  204. Really new
  205. Newb here, just picked up a 94 4Runner, have a couple ?s
  206. 4runner butt sag...
  207. Clicking noise in the lower RPM range
  208. Bed Bobbing...Pros and cons
  209. Exhaust
  210. solid
  211. Add-a leaf Question
  212. How do I find what gears I have?
  213. Bumper suggestions.
  214. ARP studs for 22RE cyl head
  215. Toyota motor nooob
  216. newbie locker q's
  217. Not sure what this is
  218. Suspension, Rims, and Tires. Need Input, please.
  219. What do you guys do for timing?
  220. does it fit into a 1985 4 cyl axle
  221. Bearing Kit For 8'' Fit a 7.5''?
  222. Noobie Help!
  223. Dual twin stick ?
  224. 87' rear disc brake conv
  225. Alternative front axles swap?
  226. trans question
  227. 22re Rebuild: Are these cam lobes shot + other related questions
  228. Will these wheels fit my 07 T4R SE?
  229. Arggggh! T100 gas tank
  230. How to mount the air intake chamber stay on the 3vze
  231. Locking Hub + Locker????
  232. a/c pulley spins when a/c is not running...
  233. 86 turbo has a wweird noise...
  234. stingers. do they work? what is their purpose
  235. 89 Yota Wont Run
  236. freaky noises
  237. 2001 4Runner..key stopped working...worn out?
  238. 4Runner Long travel suspension options?
  239. '84 pickup wont pass emissions
  240. Found some plugs unplugged; where do they go?
  241. Who makes the best crawl box adapter
  242. rod bearing repair or engine replacement?
  243. 1994 4Runner
  244. Fuel backsiphons ?
  245. Noob Gearing Question
  246. I really could use some help
  247. where is the serial number on the head?
  248. 94 toyota pickup suspension Question
  249. Few Quick Questions - 2003 4Runner Limited
  250. Couple Lift questions
