View Full Version : Newbie Tech Section
- Vacuum problem ?
- 22re coolant system question.
- Seeking Advice on Suspension Lifts
- Need some a/c!!
- headlight swap
- pilot bearings for 22re for at or standard trans
- 93-97 Landcruiser FRONT locker into Pre-04 Tacoma?
- Strange sound from motor
- Why So Hot ? Is It Normal ?
- 97-00 3.4 5VZ-FE Valve Adjustments for Dummies Worksheet
- Thermostat & Coolant Change
- Questions before diving into fuel pump replacement
- Starting problems
- 1993 Toyota X-Cab
- New 4Runner Driver here, wanting to get some basics down.
- rear 5-bolt cover leak?
- 86' Toyota Pickup Engine Issues
- Wont Start electrical problems i believe
- 87 SR5 Rear shocks bolt questions
- 1999 tacoma 2.7 4 x 4 5spd no start..please help
- what's this for??
- Timing Cover Failure sharepoint - 94 PU
- Old Clutch Question
- 1999 Toyota 4Runner electrical problem
- 86 4runner 22re starter problems
- I need a stock 'push-pull' steering arm!
- Shocks for stock height or lifted
- Clutch issues
- lower studs connecting backing plate to oil pan on 89 v6 pickup
- Best Repair Manual (22RE Pickup)
- Not getting any fuel!
- Not getting fuel
- Driveline Brake/Factory E brake ???
- 1990 2nd Gen
- Where to Buy Radiators ??
- 3vze question
- EGR hookup issue
- A different situation. '83 22r and '87 22re building a disaster!
- 1990 Yota 22re slow start and high idle
- Fuel system issues please help
- Whining squeaking noise after driving for 20 mins
- Transmission from 86 2wd to 91 2wd
- Suspension Lift Help
- 94 Runner 3.0 auto stumbles after slow down
- battery draining problem
- I need tips and advices please!
- Toyota Tacoma Cruise Control
- 1994 toyota xcab front hub/wheel bearing bad
- 04-89 3.0 v-6, tps new cold wont start loads up
- when should I replace o2 sensors?
- SAS Swap Cost
- Oil in plenum
- P0303 Misfire cyl 3 questions
- 2000 tundra fuel gage
- No start on new rebuilt 22re (another one)
- bad frame to engine swap
- What kind of locker
- Weber carb manual choke install
- Drivers Side Sags? [Pics]
- Pulley next to power steering is wobbling
- General question about frame issues
- 89 toyota 4x4 22-re wont start after oil pan pull and clean. help!!
- O2 Sensor 4 wire female plug#
- need help wid difference between 86 4runner vs other yrs
- Best Weber Carb vendor?
- 2001 Sequoia, Off Road Fuel issue
- pick up engine bay
- New owner with new project '86 4runner
- 91 toyota p/u
- 22re hesitation
- 1991 4runner 3.0 into my 1995 pickup...need help please
- 2wd with hubs locked
- 84 4Runner Dash - What's this button do?
- Can I get rid of this?
- transmission too full
- Gearing?????
- 98 4runnee leveling kit
- the hell are these blocks for?!?!
- 85 toyota Fan clutch problems
- What does an SR5 package consist of?
- Crossmember bushing
- Headers
- Ready to start the build on 3rd gen 4runner
- timming info for 91 v6?
- Head Gasket, on a 240K+ motor, Good idea?
- Rear brakes working sporadically
- Just Jackin It
- death wobble
- Emergency Break Light
- different spindle?!?
- 1990 22re runs warm down the highway
- no electrical power
- Sensors
- 1986 4 runner won't start
- stripped spindle??
- 91 toyota p/u fuel pump troubles
- 4wd problems.... any help?
- Vent window ?
- smog help
- Pick N Pull parts run
- t100 popping and grease everywhere
- Front crossmember bolt torque
- Trying to figure out what size main bearings and rod bearings I have 22RE
- non-locker to e locker 3rd gen 4runner
- A/C not blowing at all!!! 89 yota pickup!
- '94 base pickup 22re 2wd starter clunk
- Another smog question
- 22r parts
- Need Help ID'ing a part on Throttle body of '85 4Runner
- Universal Joint
- a/c trouble on my 93 4runner
- Elbe build
- Axle gearing...
- How Far up the Proverbial Creek Am I
- I need a cheap steady barring
- OIL QUESTION (Synthetic or SAE?)
- Engine Damage for running out of oil
- pre-86 suspension differences?
- Brush Guard for 89 sr5 ext cab?
- '91 Pickup-pulls left, left front wheel hot to the touch-stuck caliper?
- 22r motor help
- Heater Core Hoses
- 1985 toyota pickup always takes several tries to start
- Stiffener plate
- Do these to connections use the same size gasket ?
- Ash Tray Question
- Looking for 88 Tacoma bull bar
- How To Keep Your Toyota Alive 1975-1987 Repair Manual PDF
- Installing Manual Hubs
- over heating issue
- Gear ratio?
- axle wrap
- Cam Sprocket Question
- Advice on this crankshaft pulley bolt
- Seafoam question
- Seafoam ?
- Bell housings interchangeable?
- lockout hub problems?
- 1986 Toyota extended cab 22r motor problem
- 91 toyoto pickup jumps out of gear
- Still flashing ERROR CODE 52
- toyota pick rough start and idle
- engine problems
- electrical issues?
- 89 Toyota pick up 3.0 no spark
- Should I Replace This Ignition Coil?
- 94 sending temp sending unit ?
- Engine performance / head gaskets
- 1984 22r Idler pulley & bracket for power steering set up?
- 1986 Toyota 4x4 trim question
- My 1978 sr5 20r pick up resurrection.
- 3SGE swap into 1988 rwd pick up
- My 1978 sr5 pick up 20r resurrection and questions
- failed my smog
- ring and pinion question
- Warm up engine in the morning ? If so , how long , why ...
- Solid axel swap HELP
- OME SD33 steering stabilizer
- H-G job on 22re what did i do wrong?
- Brake light works intermittently...
- what is this plug
- 84 pickup cowl
- voltage constant messed
- Front crank seal
- dist housing? different year to year
- roof rack for 89 1st gen 4runner
- distributor year to year, are they different
- 1987 rear pinion bearing
- What purpose would this hole in the hood Serve?
- distributor all the way down. not hitting 5deg
- Door Removal Help Needed! 93 4runner!
- 4 cylinder exhaust set-ups
- Lift kit options
- Ebrake System for 86 4x4 pickup
- Following Kawazx636 desmog
- #%^*! Nuts!!!
- EGR Wire
- Improved MPG options?
- Camshaft thrust bearing oil clearance
- oil pressure
- need the name of this part
- Hole in Exhaust?? 87 4Runner, 22RE, 5 spd
- 87 4runner 22RE, 5 spd, Wacky Speedometer and buzzing dash
- Where to find 95 Pickup replacement springs
- 35 Inch Tires?
- ID These Parts Please! (Pre-ISR Mod questions)
- 1986 Xtra Cab 22R - been stored 6 months
- ifs axle overhaul
- Will a Camry knock sensor work in 3vz pickup?
- How does the Oil Cooler Work?
- ECM question
- On-Road safety questions..
- My 88 Toyota Pickup is not getting injection pulse... why???
- 4 wheel drive woes
- V6 to 4cyl. swap
- Suspension Designs, Probems, Solutions, & Tech
- Missing 4th gear in 89 4x4 Pickup
- 87 4Runner Rear Window Issues - Motor is fine
- 1987 22re miss
- Suspension Kit Question?
- Sealant
- 85 lift question
- 90 4runner aftermarket taillights
- 87 4runner "What is this part?"
- Mirror Replacement Help
- IFS Bracket Lift
- 02 Tundra overheating
- Power to the Dist?
- Temp sensor and battery ruined - massive headache
- OME Kit on UZJ100 - Looking for some help.
- T100 transmission slipping
- ring and pinion advice
- how much oil does a 3rz take?
- Looking for good inexpensive headers.
- Camshaft help
- 22re sluggish weird idle
- Steering Linkage Questions
- Front end problems
- new guy needing parts for 01 runner!
- 1986 4runner re gear
- 4 cyl max tire size?
- very low commpression
- dead #2cylinder
- B05B Rear
- Gates Water Pump
- 350 sbc swap
- Temporary tricks for disabling my truck , going out of town for two weeks
- 4 runner front seats
- solid axle swap
- Extreme Long Wheelbase & 6 wheel drive
- Best diagram/engine overview for 3.0 EFI 6 cyl.
- Gap between engine and bell housing
- 22re running rough
- earthzonealex 85 pickup 22r rust war
- 86 4Runner 22Re timing chain? bent valves?
- Aussie ifs hilux vs USA 1st gen taco
- What gears should I run for 35's
- Low RPM sputtering 22r
- Max Tire Size for 1990 Base 2wd Pickup
- What are some IFS upgrades for high speed off roading?
- I want to drop a bigger motor in my 87 4Runner 22RE
- I've looked,searched & cant find..." where do all nuts &bolts go"
- stripped spark plug wont fire now
- Looking for a transmission
- Head Gasket Replacement Overheat
- Head Gasket
- Hello
- Leaf springs
- front shocks
- It's Official. Im in Love
