Sponsored by: CARiD
ring and pinion question
Old Jul 14, 2013 | 01:58 PM
chevota91's Avatar
Exclamation ring and pinion question
Will an older 80's ring and pinion gear out of a toyata truck with 4 10s fit in a new 91 housing?? I know the older axle is skinnier but are the spline gears on the axles the same? And will the ring and pinion fit in the newer housing..
Old Jul 14, 2013 | 04:30 PM
gigatech88's Avatar
Off the top of my head I'm not sure. Search Toyota faq 2.0 on Google. Oodles of information and pictures. That's right, oodles.
Old Jul 14, 2013 | 07:40 PM
aztoyman's Avatar
Check out www.gearinstalls.com
Old Jul 14, 2013 | 07:44 PM
BigBluePile's Avatar
Possibly yes, different pinion head thickness
Old Jul 15, 2013 | 10:00 AM
highonpottery's Avatar
swapping entire differential? should be a direct swap if late 80s model. if it was a 2wd donor, then NO.
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
oldirtydirt
Feb 23, 2020 09:30 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
kirkrunner
Jul 27, 2015 07:59 PM
