Sponsored by: CARiD
EGR Wire
Old Jul 5, 2013 | 02:55 PM
737IP's Avatar
EGR Wire
I am trying to track down an EGR code and I found that the wire that plugs into the EGR had some damage to the outer insulation. As far as I can tell the 2 wires inside appear to be okay. I tried to check for continuity with my ohm meter and did not get anything. Is there a proper way to check this before I buy a new one?
94 Toyota truck 3.0
Thanks for your help.
Old Jul 5, 2013 | 07:49 PM
Punchy's Avatar
2 reasons why it fails.
1. the switch is bad, it opens or closes (I forget) when a certain temp is reached from the EGR opening correctly.
2. The EGR tube is blocked (clogged) or the EGR valve, EGR modulator, the green VSV on the passenger fender not functioning.
vacuum hoses not connected correctly to the EGR loop.
Blamalam
Mar 12, 2022 07:34 AM
montanatruck
Feb 26, 2017 07:07 AM
e_richard
Jul 30, 2015 06:50 PM
montanatruck
Jul 25, 2015 03:45 AM
Snort
Jul 9, 2015 03:58 PM
