Sponsored by: CARiD
the hell are these blocks for?!?!
Old Aug 8, 2013 | 05:44 AM
ramblah96763's Avatar
85 truck with a 2"? spring lift and theses weird little blocks or plates front left and rear right about a half inch thick for no reason! sits level and rides fine enough for a backwoods rig but I have no clue what the purpose is, ubolts look newer but that's about it. the opposite ends of the axle don't have them either
Old Aug 8, 2013 | 05:45 AM
JasonYota's Avatar
Pics would be good.
Old Aug 8, 2013 | 01:10 PM
you have a point
Old Aug 8, 2013 | 03:22 PM
Discombobulated's Avatar
Classic
Old Aug 8, 2013 | 10:36 PM
theres your sign
Old Aug 8, 2013 | 10:39 PM
make that a 3/4 block
Old Aug 9, 2013 | 02:58 AM
Stetson_md's Avatar
There for lift
Old Aug 9, 2013 | 05:22 AM
nothingbetter's Avatar
Those are lift blocks. Seems weird that they are in the front left and right rear position though. Maybe your springs are in the wrong corners?
Old Aug 9, 2013 | 08:46 PM
if that's the case then where can I get replacement springs but stay the 2ish inches over stock? the front block is still a small bit thinner than the front tho which raises another question
Old Aug 9, 2013 | 09:02 PM
rokblok's Avatar
Driver side (I think) uses a small spacer (block) to level out the truck. I believe the perch sits lower due to perch on passenger side riding against the pumpkin. Most lift companies don't make a left AND a right side spring to compensate, so they throw in a spacer since their left and right springs are made to the same specs.
I couldbe way off on this, but I seem to recall hearing this somewhere.
In regards to the rear block, one spring probably sagged more than the other so someone threw in a block to level it out. Just a guess.
Old Aug 9, 2013 | 09:26 PM
dropzone's Avatar
Fossilized
Front D/s has a small spacer.
Old Aug 10, 2013 | 03:57 AM
simple enough. anyone know where I can get some mildly taller springs? I don't like blocks especially in sand
Old Aug 10, 2013 | 05:39 AM
Chickenman's Avatar
Old man emu makes a small lift. You can find them online.
Old Aug 30, 2013 | 02:19 AM
got any ideas where this one came from? my buddy says factory lift but hes just a fanboy
Alexdosdall
Dec 10, 2017 05:48 PM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
moparbay
Oct 6, 2015 09:24 AM
Toys4parts
Sep 26, 2015 01:56 PM
