Sponsored by: CARiD
Gear ratio?
Old Jul 21, 2013 | 06:39 PM
tman19941's Avatar
Gear ratio?
I have a 95 Tacoma with a 2001 2.7l motor. Its bone stock as of now amd im trying to plan a build for it. I want to put sas under it but i dont know what front axle to look for. I want to keep the gear ratio the same as the rear for now until i find the gears i want for both axles. Can someone tell me my gear ratio and what axle i should look for? Also, i want a front axle thats a little wider than the rear so the front tires stick out a lil. I think i sound a little ignorant, but im just lost in the sauce on how to make this happen. Anything helps.
Old Aug 10, 2013 | 10:52 PM
Edionne13's Avatar
Spacers, Tacoma axle is wider. Not sure on gears but check your driver door and look at code and find it. Search on web to tell you what gear ratio you have
RatOmeter
Oct 22, 2015 03:17 PM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
