Sponsored by: CARiD
Sensors
Old Aug 2, 2013 | 06:29 AM
JerseyDevil2505's Avatar
Sensors
Running a 1992 Toyota pickup, with a 4CYL 22RE. I'm confused about two sensors that screw directly into the engine mount. One has is directly underneath the oil filter, it's connector is like a terminal, has a large rubber grommet around it, is this the knock sensor?
The other is directly to the left of the oil filter, this one had plugs, I thought it was the oil pressure sensor but the stock plug I have doesn't fit into the replacement I bought, the original one crumpled and was broken. Thanks for the tips.
Old Aug 2, 2013 | 07:54 AM
4Crawler's Avatar
Should be the pressure sender below the filter. If it is a big can with rubber boot, that is the gauge sender, I think the idiot light sender is a smaller. To the left of the filter is the knock sensor, usually a yellow color. Easy way to tell is see if there is oil behind the sender, the pressure sender will have oil behind it and the KS won't.
moparbay
Mar 10, 2023 03:50 PM
jb451
7
Oct 7, 2022 06:58 AM
Kreedy1
Sep 8, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
moparbay
Sep 3, 2015 12:48 PM
