Sponsored by: CARiD
Oil in plenum
Old Aug 16, 2013 | 08:08 PM
iinvno1's Avatar
Oil in plenum
So been having troubles with a 87 Toyota with a 22ret in it. First the fuel filter was plugged bad not injectors and oil in the plenum. What could be causing that? I replaced the injectors with brand new ones and its doing the same thing. Wont idle at all when I replaced the injectors I noticed oil in the plenum and also in the lower part of the plenum?? Brain isn't working sorry but there is four valley's ahh ahh ahh goes into the engine. Get the picture anyway has oil there as well. So runs terrible at a low speed wont idle. So im sure its because there is oil where it is not supposed to be but not sure how to fix the problem. Can someone give me a direction? Thanks folks
Old Aug 16, 2013 | 08:59 PM
Punchy's Avatar
Going down the list
check PCV valve
Check compressor exit side of the turbo for oil residue, seals may be going out.
Old Aug 16, 2013 | 10:11 PM
iinvno1's Avatar
I am new to the Toyota's. Could you please be a little more descriptive about the compressor and turbo where to look and such and what to look for. I checked the pcv shook it and it moved and clicked. Where could a fella find a schematic of the vac lines to the turbo. Wondering if I have a line in the wrong place??? Thanks again.
Blamalam
Mar 12, 2022 07:34 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
calderp
Jul 27, 2015 09:58 AM
