Sponsored by: CARiD
4 cylinder exhaust set-ups
Old Jul 7, 2013 | 11:23 AM
troyjmueller's Avatar
My experience is with mostly stock hardware, and on the exhaust side of things, I am wondering what people run.
Stock, the 75-1980 20R has a 4 into 1 cast iron manifold, and no cat (to my knowledge)
Stock, the 1981-1982ish have a 4 into 1 cast iron manifold, with a dual-pipe flange (which 'Y's downstream), and catalytic converters...
Stock, the 1982-198x have a 4 into 2 cast iron manifold, with the dual pipe flange.
The earlier manifolds between the 20R and early 22R interchange, and the later manifolds have a slightly different bolt pattern - 2 holes in the center, versus the single one on the earlier.
So, my question: If I run a split cast-iron manifold, and separate ~1 3/4" (to match the factory pre-'Y') pipes, dual small mufflers, and ~ 2 1/2" outlet (underneath or stack), what sort of power increase/decrease, economy, or sound I might expect, and whether anyone here runs something similar...
I'm also toying with the idea of fabbing a 4 into 2 header, with similar sized piping, mufflers, and outlet (conventional or stack)
Also, I'm sort of curious as to what type of set-ups you all are running...
Jayboy74
10
Dec 21, 2021 08:27 AM
Corvoid
Sep 4, 2015 11:55 AM
ManzDaKlown24
Aug 22, 2015 10:25 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Dakotaneu
Jul 27, 2015 12:03 AM
