Sponsored by: CARiD
Solid axel swap HELP
Old Jul 13, 2013 | 11:53 AM
1986YODA's Avatar
Ok so I did a solid axel swap on my 86 4runner... Rebuilt the axel put the ifs calipers on with fj 80 rotors... All the standard stuff. My question is what to do about hooking up the front driveshaft. It's has a sky offroad solid axel bracket with 2 inches extra lift and it has pro comp lift springs in the front. My driveshaft doesn't have enough angle to get to the front flange. I'm sure I'm not the only one that has run into this problem
Old Jul 13, 2013 | 11:54 AM
1986YODA's Avatar
Old Jul 13, 2013 | 01:10 PM
wyoming9's Avatar
Red face
Have a Longer drive shaft built!!
Since everything else is in place measure flange to flange
That will give you the distance you need plus allowance for movement as the suspension flexes .
There might be some factory yard ones that could work but the time it takes to hunt one.
Old Jul 13, 2013 | 01:16 PM
abeD85flatbed's Avatar
The c/v joint on the front driveline of the IFS trucks and 4runners does not deflect to the same degree as the ones used on the solid axle models. You might have to change to the earlier style c/v or see if you can find one in a wrecking yard and have it lengthened and rebuilt.
Old Jul 13, 2013 | 09:01 PM
BigBluePile's Avatar
Make one, pretty standard stuff.....
Old Jul 13, 2013 | 09:04 PM
dropzone's Avatar
Fossilized
or clearance the CV: http://www.4x4wire.com/toyota/tech/cvmod/
pretty common mod
Old Jul 13, 2013 | 09:33 PM
Redeth005's Avatar
Measure from the Driveshaft flange to the Pinion flange. Whatever distance you are short that is how much you need to have it lengthened. I only paid $120 at a local Driveshaft shop to have mine extended. I dont mess around with drive shafts. I would much rather have a professional do it right the first time then take a chance of it the new metal twisting, welds breaking under the force or whatever.... either way. it's worth the investment. Get it extent ended. If you feel confident in your own welds then do it yourself.
Old Jul 14, 2013 | 09:59 AM
pretty common mod
Just don't loose any pieces or you'll be tearing another driveshaft apart to fix it...ask me how I know
Indeed.
Rear shafts I get done professionally
Old Jul 14, 2013 | 11:36 AM
1986YODA's Avatar
I work for Lincoln electric so I'm pretty confident in my welds.... The issue I have isn't with the length of the driveshaft cause I can lengthen it... The problem is the cardigan joint doesn't let the shaft drop enough to come close to connecting to the axel flange... I can put degree shims to tilt the pinion up some but it still won't be enough to bolt up
Old Jul 14, 2013 | 11:50 AM
Redeth005's Avatar
Are you sure its not the cover for the part of the driveshaft that connects to the transfer case? I had to remove my cover too to allow the driveshafy to droop down further
Old Jul 14, 2013 | 11:52 AM
1986YODA's Avatar
Nope... Cover is off and had no effect on letting the driveshaft drop
Old Jul 14, 2013 | 11:57 AM
Redeth005's Avatar
Oooo man.... that's a wierd one. Thats what solced my problem. Have you already adjusted the pinion angle with the new spring perches?
Old Jul 18, 2013 | 11:47 PM
SHINE RUNNER's Avatar
when doing sas on a 4runner its best to dual case with long spline shaft. either way you still have to clearance the cv joints mine wouldnt connect but after clearancing the cv it hits the ground
Flying91
45
Apr 11, 2024 04:39 PM
deepmarsh
Aug 6, 2015 03:44 AM
gillesdetrail
Aug 3, 2015 04:43 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Backcountry411
Jul 24, 2015 08:06 AM
