View Full Version : Newbie Tech Section
- Catback Exhaust for 96 Tacoma
- 22RE engine troubles
- is this the rite section for hp upgrade questions?
- Quick Newbie Question
- What Tranny is in an 88 4runner 4x4?
- 96 coma left front spring sag, fix?
- Towing with '96 4-runner
- 1986 pu stereo head wiring colors?
- Start-up, White exhuast smoke?
- difficult steering
- Newbie with 4Runner questions
- bracket lift
- 99 4Runner Pwr seats fit in a '98 4runner without pwr seats?
- 22re Distributor Bushing.
- Online Parts Locator?
- ignition
- Will this locker work on my truck?
- 22re wont pass emissions!
- DC-1 polished wheels
- Clicking ticking from vehicle???
- I hate it when your DD dies in the morning...
- EGR temp sensor?
- changinga transfer case HELP!!
- Cruise Control
- Busted anchor arm on 86 Pickup
- CEL Knock Sensor
- About Gear ratios...
- 1991 toy with v6 4x4
- 88 4runner 6cyl loss of power
- SDORI and OME lift ?'s
- Need new shocks for 87 4Runner
- Tach Questions
- Won't turn over
- compression test ?
- First time 4 wheeler.
- when you regear do you have to...
- gas mileage
- used engine, what to look for
- trying to decide which 4x4
- quickie
- Are the 3.4 L V6s in 99' 4runners Hemis?
- whining sound
- 2WD Bad, 4WD good
- Need lots of help from everyone please!
- tacoma lift question
- i needa lift
- 96 coma using 90 4runner gearing?
- Stock gear ratio?? will this work??
- More Power Needed
- 1993 22 re timing chain replaced, single defined knock letting off gas
- IFS Calipers on SFA
- 3vze ticking....... vacume leak???
- regearing to 5.29?
- add-a-leafs
- Water proofing the distributer ?'s
- 3rd Gen Lift Opinions
- 87 4Runner W56 Transmission question
- new runner questions
- Is Lower Idle Bad?
- Finally looking to get started...
- 1995 3.0 4runner engine install question
- holley 2brl what throttle cable works?
- 78 FJ40 Rear Dif Seals
- Crank the t bars and 2 in rear spacers?
- 1st gen 4runner rear diff.
- Trail Gear Order Delay
- 3vze removal?
- flasher or wiring?
- 33x12.5x15 swamper bogger,what rim width/backspacing
- 1990 4runner 1/2 shaft replacement
- New 2nd Gen 4runner... any of these issues major?
- 3vze headgasket
- '93 Pickup - spark plug thread and front bumper questions
- 3VZE horsepower advice
- starter issue?
- free lift
- Isr?
- 1995 4Runner V6, Hard to start, after timing belt job
- Catalog?
- LSPV leaking
- My 2wd toyota
- my first yota what now!
- High Idle On My 22re
- Open, limited, or locking
- Lift question.
- 3VZE prices?
- strange starter issue
- Pinion paint / gear ratio
- 02 tacoma 4cyl. 100000+ miles
- Exhaust leak at Manifold...Power killer?
- Stock 2000 Tacoma wheel questions
- How much torque for headbolts on 3VZE?
- Ignition location for battery isolator wiring
- 2007 toyo wheels on older toyo trucks?
- 22re running rich! Any advice on what to do?
- melted #3 spark plug electrode in 22RE
- Newb specific help for my 86 4x4. Gutless!!
- how to do a t-case doubler
- going to order tranny parts. need help
- timing belt
- 04 Transmission Cooler On Rad Thread Size
- 95 4runner auto trans problem HELP!!
- Looking for some guys from AZ!!!
- 88 22re idles fine, dies when you try to go
- 3rd gen 4runner lift?
- Auto Shift handle removal
- SAS Welding
- Door locks
- correct rear shocks for a 2.5" rear lift (4Runner)
- 95 or 95.5 4Runner? Need Quick ID
- Difference between 22r & 22re
- motor problems
- ADL and Rancho 5000 install 93 p/u 4x4
- Accessory Belts
- Lots Of Questions!
- Any Ideas For A Front Bumper??
- 97 tacoma wont start !first post!
- Rear window woes
- Rag Joint
- another tire/rim question
- ABS question
- 22re exhaust question
- Vent Visors and Hood Protectors
- lockers maybe?
- Reasonable price to have lift installed?
- Return Hose PS 89 pickup v6
- coolant under driverside floor mat 94 4runer
- Water in drivers side floorboard
- brake pads and rotors
- My new motor won't start.
- Okay, I have read all about lifts and......
- which axel???????
- Came across a problem
- Need new exhaust.. have a few ?'s
- Wont start after replacing head gasket....
- I have some lift ?'s
- How to doublewall my bed???
- Another Rotor Thread ....
- rear diff
- might be a stupid question but......
- 1980 vin decoding help
- knock sensor code 52 nightmare ! HELP!
- newbie question about mods?
- Bilstein Shock Size Question???
- Front tires rubbing
- very dumb tranny. question.
- wheels..
- Need replacement hardware for bug guard
- 97-99 4runner, auto/manual question
- 2002 Tacoma Headlights use what kind of bulb?
- 3rd gen 4runner Lift kits ?
- truck bed seat (legal or not?)
- Speedometer
- Feels like a boat on a very choppy sea!
- 81 yota 22r need help newbie not getting fuel ??
- newbie needs help fuel pump
- transfer case/speedo
- R150F and 4cyl 22R turbo bellhousing?
- Rear window - fuse location
- back of the taillights.
- get rid of trac/panhard bar?
- 1987 Pickup Auto trans problem?
- Spongy brakes 85 truck, clutch sucks
- 4wd not engaging?
- Speedo gear stripped.
- Headgasket Recall - NEW ENGINE?!?
- Cold Start Fuel Injector?
- 20R in a '86 Yota 4X4 Truck?
- 93 p/u problem need help
- at what number does the 22re redline?
- When it comes to Bolt-on or Welded, whats better and why?
- 35's on stock suspension?
- How much Horsepower does the 22re have?
- 33's on a 4 banger
- PA Speaker Wiring from a CB?
- wheel question...
- motor swap questions
- Ford to Jeep Wheel Compatibility?
- V6 3rd can fit 4cyl rear diff?
- locking hubs better??
- Rims
- Can't Find Door Buzzer
- REVTEK lift w/ 2inch body lift question?
- Newbie checking in - my first pickup truck!
- how hard is it to switch boddies on 1st gen 4runners
- 2" BL really worth it?
- ditched it
- Tacoma rims to 4Runner?
- A lot of play in the steering wheel
- emission equipment
- "86 22RE fi swap to '84 22R stock carb
- Axle Question
- Leaking Steering Stabilizer?
- changing out rear ends
- Tow point question
- new moffler and very happy about it
- 22RE fuel pump pressure
- Ranch 5000's?
- Thermostat
- ??? near stock SAS ???
- Timing/ Compression Issue
- Mystery wire coupling (pics)
- Warn m8000 Winch wired up right?
- open wire connecters..
- Idle problem on 1986 4-runner
- few problems with questions
- 86' Toyota
- Knock Sensor
- Stupid RTI ramp question
- 93 V6 4x4 w/ new engine and paint
- tranny code
- Fuel injector issues
- Driveshaft flange removal?
- wheel problem
- Newb to 4WD IFS. Front axle shaft Q's
- center handle tailgates
- parting out a v6 88 4runner
- whats better and why, 3.0 V6 or 22re?
- Thermostar & coolant question
- u joints
- 1st Gen Runner Question...lifting
- Question!! Largest Tire Size for Stock Rims (16")
- What could cause my high oil pressure?
- New alternator, coolant disappeared?
- 1984 camper shell versus 1998
- ECU 3.0 V6 1989 Compatability
- 96-02 4runner lifts?
- Egr Problems
- lock right
- 85 Yota Timing/Injector Question
- SAW t-bar part number
- Engine removal ?'s
- Ball Joint Spacer Alignment Issues
- 4X4 manual hubs & ADD sys.
- Newbie with ?'s before purchase
- Looking at 4 Runner to buy
- Looking to buy a 4 Runner
- 50, 4 bolt, long block with 4 brl. intake, harmonic balancer, and oil pan. Out of Z-2
- Timing/Valve Noise...Help
- iam a noob not sure how this works???i got a problem?please help?
- 93 4x4 pickup w/ slight clunk under drivers side floorboard
- 1989 landcruiser oil leak
- adjusting the brake pedal
- Disappointing Exhaust
- rim width
- 2wd lifts?
- hidden fuel pump relay?
- 4Runner VS Cherokee
- New guy here with questions
