Sponsored by: CARiD
Rear window woes
Old Feb 29, 2008 | 11:59 AM
Team420's Avatar
Rear window woes
I have a 93 runner, the rear window will not move without my help, you can hear the motor, it just doesnt have enough power to move the window on its own. Any suggestions?
Old Feb 29, 2008 | 12:44 PM
Thumper3's Avatar
I experienced the same thing with mine too. The gears in the tailgate could be worn, which was my case...had some weld put in and teeth cut for a quick fix...in the meantime I'm looking for a good deal on a new regulator & motor for the window (ebay).
Old Feb 29, 2008 | 12:49 PM
4Crawler's Avatar
Might open up the door and give everything a good cleaning and lube. See if you can see anything loose or out of adjustment.
Also test the voltage at the motor and see if there is an excessive voltage drop, perhaps due to a bad relay or wiring.
Old Mar 5, 2008 | 08:18 AM
Team420's Avatar
thanx 4 the tips...i will check it out... now im busy with the brakes...all of a sudden on my driver front brake works, passenger side was frozen, and havent got to the rear yet, weird how it happened so suddenly tho
Jun 1, 2021 01:51 PM
RustBucket
Jul 24, 2015 04:46 AM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
