Rear window - fuse location
I did a couple things to my 4runner this weekend, and I took the top off and also had the neg battery cable disconnected for a while. Now, my tailgate glass will not let back up. I think it is just a fuse, because neither the inside switch or outside switch will work. However, I do not have a FSM, so could someone please point me to the right fuse, it's about to rain heavy. Thanks
Thanks for any help,
I got it fixed.
I got it fixed.
Hopefully, someone from the first gen crowd will chime in, here. I believe that I remember reading about a switch on the drivers side bed rail (I think) that disables the rear window operation when the top is off.
If you have put the top back on, and the window is not working, then that swich may not be properly positioned. I'd look in the owner's manual, if you have it.
Ain't no fuse, at least for the rear window itself:
- http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Jun 1, 2021 01:51 PM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
Jul 9, 2015 02:18 PM
icentropy
Jul 9, 2015 02:12 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
