View Full Version : Newbie Tech Section
- Downey torsion bar installation
- Heater acting strange , No Heat from front vent , plent of heat from dash and floor
- shortening driveline
- new to 22re, have extensive mechanical background and a serious issue, please help
- Gear ratio confirmed
- Replacing a leaky radiator
- Trail Master Lift kit removal
- ARG! I need help with the lift setup I want.
- 22 R-E Finding TDC
- Making Custom bumpers. how to mount securly
- 1987 Runner Thermostat orientation?
- Installing Locking Hubs on my 1993 4Runner
- door hinge rebuild kit for my '82?
- What color to paint the truck?
- Toyota Factory Replacement bed
- Lockers
- 3.4L Swap Shop in Las Vegas?
- Knock Sensor Issues
- heater casing for 90 toyota 4runner
- Tire Clearance
- 3vZE O2 Sensor?
- Steel headers junk ?
- 3rd is making noies
- Noob question...stinger?
- 2003 Toyota Tacoma CEL, NO CODES!!! HELP
- adhesive for new intake manifold gasket?
- ? c&c replacement mirrors
- 81 toyota front drive shaft. Need help
- Kennesaw Mountain Rear Bumper
- Diff drop and sway bar drop ???
- 90 toyota 4Runner with random idol and starting problems
- Question about roof racks
- straight pipe ?
- planning to get a 4runner!
- 2nd gen wont start
- 3.0 transmission on 3.4
- isr mod oil leak
- Battery and Brake lights flashing
- Check engine light flashing
- carberator problem
- repair manual
- regear? broke lugs. bad motor...bad purchase?
- anyone tried this? 86 4Runner to chevy 4.3 v-6 conversion
- Big 3 ?? Truck wont start
- high idle
- 84 toyota tranny ???????
- blinker to runner light conversion
- Shackle bolt question
- Just bought a 1993 4Runner ...
- Squirrel chewed an injector wire, what to do?
- Need help with part id
- First time rebuilding top end
- 93 pickup frame rusted thru
- rear brake portion valve 1985 toyota 4x4 pick up 22re sr5
- Filter pcv
- 88 4-runner headlight replacement
- Instrument Cluster Bulb Replacement
- 92 3.slo to a 96 3.4 motor swap
- Filter info????
- 85 rear end???
- about to pull trigger on 33x12.5x15 quick question
- Knock Sensor Worries
- engine cuts out at 3.5 - 4 grand like a rev limiter
- efi to carb swap 22r
- 1986 Pickup interior fuse box removal?
- Mean1982 = 1982 Build
- 22re wont pass 1900rpm???
- New BFG A/T Question..
- suspension
- I want to learn more...
- need to find out gear ratio
- 2nd Gen 4runner gauges into 1st Gen Gen 4runner?
- Gearing swap
- 94 Pickup blinker issues
- Yellow plastic screw on intake manifold.
- 94 SAS Front Lift Spring Question (Please Look)
- Afm swap question
- 22 r reasonable hp gains with bolt on stuff
- Zuk Mod Questions
- strange noise
- 1985 toyota pickup automatic problem
- need help 1993 4 runner 22re gear questions
- whats the best way to paint rims
- Lifting points on 3.4L?
- picking up my 1988 4runner tomarrow
- Quality Front End Parts are OEM
- 4WD wont disengage
- New 22Re block, should i use a carb, EFI, or propane?
- Mystery noise when driving
- trouble setting timing - please watch vid
- I need 4.88 gears for my 1997 4Runner 2WD
- R150 to R150F conversion
- Shift Pattern?
- 96 2.7 tacoma starter issues
- What kind of grease do you use in birfields?
- Muffler Advice
- no power after timing done
- 1988 toyota pick up 2 and 4 wd body panels
- lift question
- Engine vs. Transmission - which lasts longer?
- Ideas on IFS
- 1988 4runner 3vze
- 4 runner brake pedal too low
- Ideas for a 91 pickup
- Best radiator at best price from best vendor
- Lift Kit, should I use blocks or add a leaf?
- Where can I get a new IFS truss
- 1987 pickup wont go over 60mph on highways
- 1980 20r Pickup Rod Bearings & Timing Chain Tensioner
- Supercharger or Cold air intake?
- Does it matter which ATF in power steering system?
- Catalytic converter info needed
- Supra afm swap?
- Is my block trash???
- fuel issues
- How do I restore my rear window function?
- wat gears 22r pickup 31x 10.5 wheels
- Anyone ever change steering fluid in a 99 runner?
- Leaf springs
- Rhino Liner??
- 4" ifs rough country lift + bj and coil spacer lift?
- PRP Seats
- Trouble replacing harmonic balancer / 90 p/u
- rear brake portioning valve removal?
- Whats the name of this part.
- new to toyotas...need 3.0 swap help
- first time greasing gone bad
- 97' 4Runner SR5 Rough Idle, Bad Exhaust Smell
- 22r Oil light problems and knocking sounds
- Check Engine Light - On then off then on?
- Build your own bumper starters: ideas/pointers needed
- My truck won't crank
- Lift?
- Cat questions.
- I'm still looking for a rear diff gear lube clarification on my 99 runner.
- Where did the Tacoma antenna whip mod go?
- Idle poblems
- 22r Weber and offen. intake help!
- installed 4:56 factory diff in third member "problems please help"
- what size wheels are you guys running
- Wheel spacer help
- Preparing 3rd Member For Installation
- Yota choking down
- 89 4x4 wont go pass 67 mph on highways
- 86 pickup question
- Random Question about stock radios
- Swap Ideas 1995 Toyota 4Runner
- Understanding steering rack and other front end parts
- Chevy wheel question
- 1993 2.4 truck Timing chain issue
- 1984 Carb intake/header to 22re?
- Daily Driver/Weekend mud A/T Tire Recommendations
- emergency brake light comes on and off randomly?
- Help with odd sound coming from '93 4runner
- Spring Hanger Questions
- Trying to put 22re head on 22r block
- Distributor and plug wire advice
- Replacement Transmission, where to buy?
- How to find axle nut
- No0B! 2005 Toyota Tacoma Prerunner
- Need help with my 90 Yota
- Swap 90 22re into 86 questions?
- manual hubs and spool up front
- 89 pickup leaf springs
- Aisin hub purchase?
- Rough country lift question
- Will it fit ? Add a leaf...
- 4x4 noob
- antifreeze in oil
- Small Gears+Big Tires=Less Performance: A Query
- trying to figure outhow powersteering pump bolts on block
- 1980 Toyota ignition module
- First 2 nd gen
- Rough Idle 89 22re 2wd Truck
- Aisin and/or Warn hub advice
- help broke down...... question
- lower gears in old axles
- 1992 4runner transmission swap
- 2004 4Runner hatch won't open
- crankshaft position sensor
- Question about Wheel Backspacing
- Bar's Leaks
- thoughts on these upgrades
- Carb Problems
- Engine idle speed lowers when headlights are on
- won't start up!
- Charcoal Canisters
- Unstaking pinion nut
- windshield wiper replacement
- 1999 suspension upgrade on my 1997 4Runner
- 4.56 gears going into 1983 toyota 4x4. Are driveshaft bolt patterns and size the same
- Spark plug and wires recommendation
- starting problems and fuel pump
- 84 fj60 v8 conversion advice
- reverse hum
- What Truck to Start With?
- tire size
- 93 toyota 4x4 v6 black coil wire hoat all the time why?
- 2 inch sus lift with stock height rancho shocks?
- 1981 toyota 4x4 gas gauge not working??
- Pickup Fuel Capacity
- o-ring for distro cap?
- Cant find detailed EGR removal guide.
- just bought my first yota!!!
- 1990 6cyl missing
- 22r in 20r rig
- Need to set up 2010 tacoma for special work.
- Quick Question about ifs locker
- Oil filter crossover
- 08 fj 87 4runner radio swap
- Newbie in need of help
- Brake Upgrade Recommended for 31s?
- 87 Runner green light on lower dash near steering column
- new u-joints-3rd member and still noise!
- Question about 97 4runner
- loosing antifreeze?
- 87 Samurai with full 83 Toyota Drivetrain...
- shifting problems
- Rear Brakes
- 1991 22re 4cyl water pump replacement
- 1995 Toyota T100 tire rubbing
- 2nd Gen Gauge cluster swap-tach?
- Hella 500 mounting bracket problem
- cv half shaft
- To sell, junk, or repair?
- Whining noise?
- 22R Starter Shims????????
- Starter is making a clicking sound . Need help with diagnosis
- how hard to replace timing chain on '93 3.0V6
- LIGHTEST, cheapest, easiest way to get 400hp for my prerunner
- '93 4Runner, Engine swap or cut loose
- My Exahust smells rich
- Need help PA/NJ
- Limited vs SR5?
- Front/Rear Spring Selection.
- diff drop
- Tranny pops out of first?
- Starter Question
- my smokin 82
- New Starter, still wont start
- exhaust- what to expect
- T100 owner need opinion: 2wd or 4wd 5spd or auto
- what kind of damage am i looking at if i run 37s with stock ifs 410s with the 22re?
- What is the proper and safe way to put my 4runner up on jack stands?
- Engines that work best, or fit for swapping into the 84-85's
- 99 toyota 4 runner brakes
- Bump stop need to shut up !
- Oil spraying out of engine block behind motor mount.
- brakes upgrade..?
- Are 2WD and 4WD 3rd members interchangeable?
