Sponsored by: CARiD
starting problems and fuel pump
Old Oct 20, 2010 | 06:22 PM
eddlg01's Avatar
Question starting problems and fuel pump
Hi every one... OK, my 89 1 ton truck is not getting any power to fuel pump when ignition is on the on position, but if i try to crank there is power but as soon i let the ignition go the power goes away. jump the pump direct from the battery and it ran, but now i check in the fuse box and one of the relays seems like there is a short. When y connect the relay with 3 plugs the one next to it it shows low power on #2 according to the relay diagram i should have continuous power on1+3 but 2 has a low voltage. check the relay under the glove box by computer and there is power only when i try to crank the vehicle. Now the truck has no spark from the coil, check the coil on other vehicle and is working. Can the ignition control module cause a short on the relay. I'm lost now
check both fuse boxes out and everything is good, no burn wires.
puffin04
Jul 10, 2015 09:17 PM
rbravo1
Jun 29, 2015 01:34 PM
kazuya2416
Jun 27, 2015 12:24 PM
94hiluxZE
Jun 22, 2015 10:42 AM
Dennis140
Jun 17, 2015 10:37 AM
