Sponsored by: CARiD
Spark plug and wires recommendation
Old Oct 20, 2010 | 07:28 PM
Skinamer's Avatar
What brand plugs and wires do you recommend for a 22RE? Denso, NGK, other?
I want the best I can buy that has EXCELLENT emi/ noise suppression.
Old Oct 20, 2010 | 07:44 PM
iamsuperbleeder's Avatar
NGK for both, a thousand times over
Old Oct 20, 2010 | 08:08 PM
Skinamer's Avatar
Is it worth the extra buck to get the iradium plugs?
Old Oct 20, 2010 | 08:11 PM
AmpedRunner's Avatar
I would say bosch twin platinums myself they worked really well for me and seem to be lasting
Old Oct 20, 2010 | 08:22 PM
SoCal's Avatar
Toyota needs NGK. Even a Toyota tech will tell you NGK is the only thing if you want it to run as designed.
Old Oct 20, 2010 | 08:23 PM
Elton's Avatar
really now toyota's only like ngk or denso
Old Oct 20, 2010 | 08:30 PM
Idk man they work really well in mine, after I put them in I even got water vapor out the tail pipe from complete combustion. maybe my runner is weird
Old Oct 21, 2010 | 12:46 AM
wyoming9's Avatar
Red face
I just use the Toyota wires and plugs anymore.
I had so many problems with the after market wires I switched to Toyota wires and the problems went away.
The price is on par with a good set of after market wires.
Old Oct 21, 2010 | 04:07 AM
pruney81's Avatar
NGK plugs and wires. No need to get anything more than that. They can be found at most auto parts stores.
Old Oct 21, 2010 | 02:31 PM
hamish_18's Avatar
to put in my 2 cents... I have a 93 v6 pickup. I had the napa lifetime warranty wires, and Bosch+4 plugs. I was having weird mis fire conditions, and a huge hesitation at lower rpms. I took it to multiple mechanics who never could figure it out. So I finally snapped and took it to the toyota dealer. The mechanic instantly started taking my plugs out and replaced them with stock ngk's and new toyota wires. He went with me for a test drive, and explained that he has seen this for years now. My truck has never ran better since. I will never buy anything but toyota stuff now. It just works.
Old Oct 21, 2010 | 04:03 PM
Skinamer's Avatar
Does Toyota use NGK wires too or just plugs?
Anyone have any experience with the new NGK Iradium Plugs?
http://www.ngksparkplugs.com/product...x.asp?mode=nml
Old Oct 21, 2010 | 05:09 PM
DethYota's Avatar
Try to use the V-Power NGK plugs in our old tired engines if you can. The Iridiums will burn too hot for our engines (Unless you have done other modifications).
I Put in V-Power NGK Plugs Part #1233 and BWD Select Wires #CH5414
This is for my Gas Powered 22re btw
Old Mar 28, 2013 | 01:39 PM
-City Slicker's Avatar
similar question.
my truck has 138K
with a battery intake swap
& a 2.25 inch exhaust
im going with NGK:
but should I go V-power or iridium
should I look at the current plugs to find out..?
raptor510
Feb 17, 2017 07:11 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
cars-guy
Jul 11, 2015 07:51 PM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
