Sponsored by: CARiD
Tire Clearance
Old Nov 23, 2010 | 10:26 PM
xc90V's Avatar
Tire Clearance
What's the absolute biggest tires can someone go on a stock (no lift) 4wd extra cab 1985 toylet?
i have a set of 31X10.5X15 Dunlops but before I attempt it I'd rather know first, Thanks
Old Nov 23, 2010 | 10:43 PM
peow130's Avatar
As big as you want with the proper offset and the sawzall mod.
Though, With an AAL in the rear, and front i suppose since you're 85, you could easily fit 33's without problem.
Old Nov 24, 2010 | 06:30 AM
4Crawler's Avatar
On stock wheels (15x6), they would probably fit OK, on wider wheels, likely to rub up front at the back of the front wheel well. Had a buddy who used to run that tire on a set of 15x8 steel wheels and he needed to add a 1" longer front spring shackle to get the tires to stop rubbing. He did not do any wheel well trimming though.
33s will be harder to fit, I had 3.5" lift and 33x9.50s on stock wheels rubbed bad (even w/ trimming):
- http://www.4crawler.com/4x4/4R_suspension.shtml#Epilog
Took a longer front shackle, 1" body lift and moving the axle 3/4" forward to fix that rubbing issue.
Old Nov 24, 2010 | 07:16 AM
Swimmerboy2112's Avatar
37's no lift, lots of trimming.
Old Nov 24, 2010 | 07:20 AM
dropzone's Avatar
Fossilized
by calling your truck a Toylet are you implying you have a Chevy powered Toyota?
Old Nov 24, 2010 | 07:24 AM
rattlewagon's Avatar
That Runner on 37 is pretty cool. I like the cut job on the fenders. I bet both rub pretty bad when stuffed. haha.
Old Nov 24, 2010 | 07:36 AM
waskillywabbit's Avatar
Black 4runner above has 3" lift I'm pretty sure.
That looks like Finks old 4Runner.
:wabbit2:
Old Nov 24, 2010 | 08:44 AM
iamsuperbleeder's Avatar
:wabbit2:
yeah the center point of the wheels looks a little too far away from the body to be "stock"...
on the front anyways... could just have a lift and a bad case of the sags in the rear
Old Nov 24, 2010 | 08:49 AM
I think you may be right, the pickup has no lift though i know that for a fact.
Old Nov 24, 2010 | 09:21 AM
bobby_duce's Avatar
to answer your question with 31" tires, yes.
Old Nov 24, 2010 | 10:49 AM
4x4YOTA's Avatar
I ran 33x12.50 no prob on my stock 85 4runner and then ran 37x13.50 just required lots of trimming but still did it
foampile
Dec 18, 2022 01:29 PM
djpg2000
Nov 11, 2020 04:56 AM
89fourrunner
Feb 17, 2016 06:52 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
coffey50
Jul 28, 2015 10:55 AM
