Sponsored by: CARiD
shortening driveline
Old Nov 27, 2010 | 05:28 PM
sleepygreen's Avatar
someone in my area is selling a sas'd truck but he says the driveline needs to be shortened. it was previously a 2wd. Its lifted so i would think it would need lengthening. Is the 2wd shaft a lot longer or something? its a 1990
Old Nov 27, 2010 | 05:37 PM
xxxtreme22r's Avatar
when adding the transfer case to the transmission this will cause the factory rear 2WD driveshaft to be too long. So that sounds pretty much accurate. I don't know if a factory rear 4WD driveshaft will work or not, but it might be an option.
Old Nov 27, 2010 | 05:51 PM
SpecialScottie's Avatar
It dosnt cost too much to shorten a driveshaft
Old Nov 27, 2010 | 05:56 PM
depending on where you are located I do have an early 90's rear 4WD Driveshaft you can buy from me or try out if your close. Was saving it for a spare, but I can get plenty of them if I need to. Haven't even tried to see if it's the right length for my 87 yet. All it's doing is taking up room in my toolbox. lol. Not willing to ship it though.
Old Nov 27, 2010 | 06:22 PM
thanks but i live far away.
i didnt even think about the transfer case, it all makes sense now! ill try to find a 4x4 drive line and see what happens.
Old Nov 29, 2010 | 03:24 PM
i tracked down a 4x4 drive shaft in my area. does the rear driveshaft typically work alright without being lengthened with about a 5" lift?
ktm192k
Oct 1, 2015 08:47 AM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
Odin
Sep 24, 2015 04:38 AM
djpg2000
Sep 7, 2015 10:36 AM
