Sponsored by: CARiD
Starter Question
Old Oct 9, 2010 | 03:59 PM
jp2112's Avatar
Starter Question
My starter sounds like it's engaging, but it will not turn over. The motor ain't locked up, and the battery is hot. I also checked all the wires and connections and they are tight. I have put two different starters on it and it does the same thing. What could be the problem? oh and I have an 86 pickup if that would make a difference.
Old Oct 9, 2010 | 05:54 PM
myyota's Avatar
Pull all the spark plugs out and see if the engine will crank, you could have a blown head gasket and there might be water in the cylinders causing the engine to lock up.
Old Oct 9, 2010 | 05:59 PM
desertcamper67's Avatar
If you take a jumper from the battery or the battery post on your starter to where the much smaller switch wire connects will it turn over? If so then the switch wire isn't supplying enough amps to effectively trigger the switch in the starters you've tried. Do you hear a click or is it turning over but weak?
Old Oct 9, 2010 | 06:29 PM
85 4runnen4life's Avatar
How would a guy fix this issue?
Old Oct 9, 2010 | 06:56 PM
4Crawler's Avatar
Assuming that you are hearing a loud click when you kit the key, here is a quick test:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
And some possible solutions:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Old Oct 14, 2010 | 02:42 PM
jp2112's Avatar
Ok, I ran a jumper wire to the starter and got nothing. A buddy came over and when he turned the key over I noticed that the click I heard wasn't coming from the starter. It was coming from the gold metal box (relay?) that mounts on the fender right past the fuse box. Is this where my problem is at?
Old Oct 14, 2010 | 02:46 PM
4Crawler's Avatar
That sounds like the starter relay:
Old Oct 15, 2010 | 11:38 AM
Zoofa's Avatar
Just to clarify "won't turn over" means the starter isn't turning the engine at all?
I agree with the others; either your relay is out or you need new contacts. And since you've already replaced the starter, it is probably the relay.
Old Oct 16, 2010 | 08:04 PM
nothingbetter's Avatar
Step 1 with all electrical problems. Check and clean all major grounds (engine grounds). Your starter uses a lot of power. Your grounds might be strong enough for your door chime and head lights to work but not enough for your starter circuit. Follow the advice above about the relay.
Old Oct 22, 2010 | 03:25 PM
jp2112's Avatar
Ok, the starter won't turn over at all. I replaced the starter relay, and it(the relay) will click one time when I first turn the key. I replaced the ground from the battery and cleaned all other grounds. Now, when I run a jumper wire from the battery to the starter it arcs on the little male connector that's on the starter.
Old Oct 22, 2010 | 04:37 PM
Philbert's Avatar
(somewhat of a hijack....)
SO the other day, I drove somewhere local, parked, got in 5 minutes later, and went to start the car and..."griiiiiiiiiind".
Sounded something terrible. Like the starter was turning and not engaging maybe? Sounded very violent. I pulled out my "the Club" and whacked my starter a few times...got back in and it turned over just fine.
Any idea what the heck that was????
(end hijack)
Old Oct 22, 2010 | 04:40 PM
xxxtreme22r's Avatar
(end hijack)
a bad tooth or two in the flywheel or starter will cause that if it doesn't catch just right, or simply the starter solenoid plunger did not extend out all the way.
Old Oct 22, 2010 | 04:45 PM
Philbert's Avatar
thanks!
So, not a huge deal to worry about? I thought it was a solenoid and that's why I whacked it.... Is it an indicator of terrible things to come or just a mild inconvenience like I experienced, every once in a while you think?
Old Oct 22, 2010 | 04:49 PM
I wouldn't worry about it unless it stats happening more often. probably just the solenoid.
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
