Sponsored by: CARiD
4 runner brake pedal too low
Old Nov 6, 2010 | 09:35 PM
billkmiami's Avatar
My 97 4 runner 2wd truck's brakes work well but the pedal almost goes to the floor before the brakes grap- I replaced the front pads a week ago and it did help slightly. But the pedal still grabs low- if I pump the brake, it does seem to build up pressure. Is the master cyclinder worn? My truck has over 161000 miles on it with no major issues. What is wrong with the brake system? thanks!
Old Nov 6, 2010 | 10:41 PM
BrutalIntegrity's Avatar
could be anything... bad booster or a leaky wheel cylinder... try bleeding the brake system first. look for busted or leaky brake lines or hoses. also check around the master cylinder for fluid leaks. usually when you replace the pads you should machine the rotors if wihtin specs....or replace the rotor with new...
Old Nov 6, 2010 | 11:18 PM
JBurt's Avatar
^^+1. I've got the same problem. Just replaced my brake lines. It helped, but not enough for me to be happy. I'm going to check the wheel cylinders when I've got some free time on monday. It's a pretty common problem. There are lots of threads about it if you search for them. Good luck.
Old Nov 8, 2010 | 04:24 AM
billkmiami's Avatar
No brake fluid leaks at all- master cyclinder if full with brake fluid- brake lines don't seem to expand when brakes are applied- i am still thinking master cyclinder??
voiddweller
19
May 2, 2016 09:10 PM
Sandman
Jul 23, 2015 08:15 PM
gog1968
Jun 22, 2015 05:55 AM
Mr.Black
Jun 21, 2015 10:17 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
