View Full Version : Newbie Tech Section
- Unknown Plug Connectors on 87 4runner R???
- 1986 22r ac belt
- 1985 Toyota Sunrader Key Stuck in Lock Position
- P1130 Toyota highlander
- Ball joint removal tool
- 93 toyota 4x4 (chevy sbc swaps)
- Correct value of MAF at idle on 2008 4Runner 4.0
- 95 Toyota pickup was under water, can it be saved?
- Trying to start 96 4runner 3.4L SR5
- Order of Operation - Repairs for 1st Gen Pickup
- Will a 22re motor and 5 speed manual transmission from 92 toyota fit 84 t
- Suggestions With buying new cam for 22R
- 22 re rebuild and fuel issues
- Where is the location for the fill and drain plugs manual transmission
- 22RE dies at idle
- 3vze New longblock installed, not firing
- cost
- 79 Longbed 4WD Pickup in TX: Oil & TransAny
- Car wobble
- 3VZE No Spark, No CEL when key on
- 87 4x4 22R suddenly running rough
- Rust on a bull bar
- Dashpot replacement?
- My 2000 4runner is having a hard time accelerating
- 94 4runner 3.0 3vze misfire and more
- Tire upgrade
- 1992 22re check engine MAF
- Part question starter relay
- Reverse
- Axel for 1992 pickup
- 22RE Ignition Coil replacement
- Advice on buying newer onroad/offroad 4Runner?
- Need help choosing shocks for 95 4runner
- Help with identifying suspension lift!!!
- Brake problem
- 93 22RE cranks, but will not start
- 22re mods
- 22re Exhaust systems
- Not shifting into 4 low
- Rear diff.
- 2010 Sequoia Truck over heated & rough idle
- 90 2wd 1/2 Ton pickup caliper pistons stuck
- easiest way to remove cranshaft pulley
- How do you know if a flywheel needs to be replaced or machined?
- Tool to back transmission away from engine
- How much FIPG is too much?
- Do you remove the crossmember, bracket, or just transmission mount?
- 86 Pickup Recommended Body Lift height
- Replacing the clutch - I am stuck at the starter motor - where are the 14mm bolts?
- Trouble with shifter boot with a 3 inch body lift on 89 22re 4x4
- overheating
- Vin codes
- Door chime removal
- 1996 with 2001 engine
- Overheating problem on my 1988 toyota 4x4 truck
- Part name
- value of 1978 Toyota chinook camper good shape
- 87 22re timing
- Help - 94 4runner 3.0 cranks & Runs but looses power
- 1987 22r Toyota Pickup 4×4 5-Speed sometimes doesn't start
- reverse problems
- 1986 4runner 22re won't stay running after HG replacement
- 94 4runner 3vze
- 2006 Toyota 4Runner making ticking sound ?
- 1985 22RE engine/ignition wiring harness wiring help
- Going In To The Transfer Case
- Rough idle
- 1986 22re - coolant leaking issue
- Issues with AC Clutch or Compressor?
- 96 Tacoma OBD p0171 p0172
- Need help with random wire when changing altenator 84 Pickup
- Weight issue
- alternator not charging battery
- carburator
- 87 toyota truck carb issue
- clogged exhaust
- 87 22re engine will not turn over
- 1988 4runner V6 engine - reliability
- Leak? Coming above Tcase
- 1995 automatic 4runner flat tow
- Broken clutch release fork replacement
- Manual Transmission Fluid - Does anyone ever check or replace?
- calif smog yeppie
- Fuel leak
- 86 4runner starter issues w/battery light on
- 1989 p.i.t.a yota Bad wobble and vibration
- 93 sr5 v6 3l timing belt hack job?
- Coolant Temperature Sensor Wiring
- New (to me) 91 Pickup Seeking advice
- 96 tacoma failing smog
- 1988 Toyota question
- Engine won't continue to run
- Front brake job
- calif smog on swap
- 3.4 swap backfire through intake!
- New to Toyota pick ups
- fan clutch removal
- 1994 yota with 22re engine
- Bent connecting rod?
- knock sensor wire bad
- 22r timing problem
- Need help - 3vze 3.0 V6 in 95 4Runner
- Thermostat
- ecu pinout location
- 95 4Runner trans cooler - where should I mount it?
- short sputtering while cruising
- Code 52 how to diagnose
- 1990 hilux with a 22r runs horrid on both LPG and petrol
- Mirrors...
- Iac valve problem!!
- 1980 Celica
- R151f balance weight
- 4x4 indicator lite
- 86 22r pickup struggling when idling, shuts off
- Plugs
- 91 Hilux Surf Questions
- What is the harness...
- 80 yota needs another fuel tank
- Decal or stickers? Or stencil?
- Gas Cap Door How to Open w/out a Key?
- No Power under load
- Code 24/31/25
- 22re Coolant in Cylinder
- Need Guidance
- 1984 Pickup 22R - replacing engine - quick question
- No power/code 25 (lean air/fuel ratio)
- What is this?
- Code 31
- Overdrive not working
- Obsessed motor sports
- r150-r155 transfer cases
- Maybe a trucker can help me with a 1982 Toyota Celica 2.0 ST coupe.
- 22re no power and a code 25 (lean air fuel mix)
- 95 2nd gen wheel bearings ?
- HELP! Yota newbie
- 1985 pickup vs 1st Generation Tacoma
- wipers don't work 98 4runnr
- Transmission options?
- Trouble finding O/B code
- Warm Crank
- Fuel injector rebuild
- bad VSC chip?
- Vacuum lines on a 1993 4runner
- Newbies, tell us what you drive
- Another valve cover gasket question. But also are billet half-moon seals worth the $
- 1985 toyota 4Runner w/ AC Heater
- De smoging a 1976 pick up
- Where can I find a speedocable?
- Any idea why my yota died breifly?
- 97 Toyota Tacoma dlx 5.7 swap
- Flat towing a '93 4runner w/ 5 speed trans...?
- Gas tank swap
- Rough idle after bvsv replacement 1995 4runner 3.0
- What debugging steps do you do when you get a P0133 (O2 sensor circuit slow)
- One reason to inspect your tires closely every time you rotate them
- Clutch types
- 3.4L Fuel Ratio / O2 Sensor Connectors Same? Different?
- Sbc 2wd 94 toyota pickup
- PSA: Don't skip the 1/2 mm adjustment step when doing your drum brakes!
- pictures of throttle linkage
- IFS Control Arms
- 92 pickup RWD 22RE Fuel and crank issue
- 1999 4runner limited
- mechanical issues with 6" lift on 1999 4runner
- HELP ME! Rear Diff Lock Issue
- Crank but no start 97 4Runner
- 2000 4Runner LTD Supercharged overdrive and 4WD not engaging
- Did front brakes & bleed - what could I have done better (especially that torn boot)?
- I need help!!
- Timing chain Guide options?
- Idle issue
- Check engine light stays on and throws no codes
- Aloha
- 1992 SR5 cruise control not working
- 3.0 engine driving me insane
- 1994 3slow 4runner destroying my bank account and will to live
- Front Diff Rotating a Bit with Unlocked Hubs
- Need gentle advice on ADJUSTING clutch pedal bolt please
- 92 22re timing chain
- 92 4Runner Build Advice! High Idle?
- (Probably simple) '86 4runner engine bay fusible link question
- Lack of Power in 89 pickup with 3vze
- straight pipe vs cat vs highflow
- Cross Threaded Caliper Bolts HELP PLEASE
- can dual fire plugs be replaced with regular ones? auto zone sold me regular plugs
- 1990 3.0 no start
- frame swap
- 1993 4runner 3vze. One click, then nothing
- '94 4runner no throttle response
- 87 4runner
- gas pedal bushing
- 87 4Runner no blower fan
- Clutch issues, seemingly worse in 4x4
- Diagnosis Help - 1990 Pickup 3VZE-1
- 88 Toyota Pickup Starting Issues
- 2001 4Runner 3.4 rare hard cold start and die
- Can anyone tell me what they get when:
- Understanding what model I have here in the UK
- backfires and won't start
- Backfires and won't start
- Old Pitman arm, Stuck, what to do
- Hard Shifting -- Bad Tranny or Master-Slave?
- TRD 1st gen (grey) supercharger vacuum leak
- more power 22re turbo
- 22re igniter conversion with tccs distributor
- @004 Tacoma 3.4 4x4 AT replacement
- Still confused on my sense wire
- Ring/Pinion Gear Upgrade '88 IFS???
- Runs rough
- 94 yota loses power
- goes into gear, does not move...much
- Headlight wiring and turn signal switch combination-bypass?
- Installing new cam and valve train
- 2RZ Carby, is it feedback controlled
- 1992 22re Iac valve hose connection
- Vibration at 60 97 four runner
- Fuel Starved when hot
- Newbie suspension drop question
- 1995 pickup dlx 4x4 engine swap options besides a 22re
- Starting problem
- 1997 Toyota 4-runner 3RZFE 2WD 5speed manual W59 transmission shifting issue
- Slave and master cylinder for clutch
- Repeatedly failing mechanical fuel pump
- 1987 4x4 22R engine blowing smoke uneven compression
- Seat covers
- spindle bushing thread pictures
- Smog Parts. What are these?
- swap Tundra for Tacoma bed
- Rear O2 Sensor Help
- 20r head
- Should I go for it?
- 1986 4Runner Diagnostic Ports - I think I blew something
- 88 Pickup wont run for long
- Need new engine
- Advice buying 1983 4x4
- questions help!!!
- Marker light out and squeaky carrier bearing?
- 86 Pickup electric issue
- 85 OME Dakar help needed
- New to forum! Purchased a 77' Chinook
- 93 4Runner 3.4l swap?
- 86 toyota pickup
- acceration and Transmission issue
- 1989 Toyota Pickup
- Code 41 and 43 on 89 Pick Up
- 1994 pickup blower motor
- Shocks for a 1988 Toyota 4wd Pickup
- brakes
- Best option for a 4" IFS lift with proper rear springs for a 91 Yota 4 X 4
- LSD for 1982 4X4 pickup ? Is this possiblle to use oem out of something else ???
