View Full Version : Newbie Tech Section
- Want to learn everything about the 22re
- Replaced Circuit Opening Relay now no power at all? Please help!
- NO brakes
- Might I just take a minute and show off my rattle can paint job?
- Leaf spring bolts 1991 SR5
- 22re fuel issues
- Trans Fluid: Changed 3Qts. Went from Brown to Red?
- toyota door lock- locksmith?
- My Carb Fills With Water When Filling Radiator- Why?
- Need help identifying what this part is on 1993 4runner
- 22re motor swap question.
- Anyone have 1st Gen Tacoma that doesn't have frame issues?
- 4runner 95 driver side axle
- 89 toyota pickup 3.0 o2 sensor wiring HELP!!
- Newbie
- Weird 22re issue
- Whole lota lift
- 3rd Gen Moonroof Interchangeability
- easiest locker to install?
- Hydro assist with stock steering; good idea?
- 2004 Tacoma Interior Light upgrade?
- 87 pickup running problems
- Question on tire and wheel fitment
- What is this part
- 1996 Tacoma 2.4 stalling
- FYI: flexseal works
- Interference or not?
- Help diag my misfire
- 86 4runner Flywheel bolt issue
- Rear diff and preventative maintenance
- Intake help got pics
- Fuel issues
- Please, educate me!
- 4Runner Longevity and Parts?
- 1990 Uhaul truck trans issue
- 88 ln65 4x4 gauges and meter lights stopped working
- No heat
- Headers
- 2003 frame engine mounts
- How to remove IFS steering Knuckle
- 95 4runner - 5 speed problems
- Top 20 Front and Rear Suspension Mod Questions for Noobs
- Dropping the fuel tank on my 89 pickup
- doing it all at one time
- 1979 fuel tank
- Bolt size
- Frame Broken, Sheared off, Bent -- What do I do?
- Sound from engine, normal or is something not right here?
- 3rd gen 4runner clutch parts TOYOTA OEM REMAN?
- Newbie Transmission Question
- 2001 highlander
- Swapping 4 SPEED to 5 SPD or new axle gears?
- 3.4 swap
- Anyone in Durango that knows 22re's prett well?
- rebuilt 22r knock video, help
- Best way to lift front suspension?
- 1995 3VZE and the inevitable head gasket dilemma
- 90 yota
- 89 stalls and cuts out
- Another lift question?
- Hood Adjustment 91 4runner
- 86 22r questions.
- Missing Radiator Lines
- 1992 4runner 3zve dash lights wont go off
- Front axle seal
- Drum Brake Drag
- 22re valve adjustment help
- Gear Ratio Calculation
- 1990 Toyota Truck V6 Rough Idle When Cold
- Trans Question!
- Collector plates in Washington state
- 96 tacoma very hard to start cold sensor testing?
- Brake Malfunction Lamp on
- What is this part?
- 99 4Runner Limited 4X4 with V6
- 2001 Tundra 5VZ–FE cam seals.. Is it secret info?
- 22re timing pulley mark 180 off
- 92 lexus 400 v8 into my 92 4x4 deluxe
- 22re new piston question
- New to the forum
- 95 4cyl engine adjust
- How much do gears and a rear locker cost for install?
- 94 22re - two issues
- FZJ105 Droning
- 1985 Trans Problems
- Good non-engine things to do during a rebuild.
- 1989 Truck problems
- 2nd gen r150 into 1st gen
- 2003 Tacoma no start when cold.
- 87 4runner shifter bushing question
- What to do with the radiator- 350 Conversion options?
- 86 4 runner coolant hose
- Purchasing 1994 toyota 4x4
- 2004 4Runner 4spd V6 tranny service
- 2004 4Runner strut and shock replacement
- 2000 Toyota Land Cruiser New bee Here
- Moog Ball Joints
- No power, misfire, 99 3.4l Tacoma
- PCV issues??? need some help!
- 1st gen tacoma rear shocks
- replaced the following, what else?
- The new silent motor
- Auto shifter swap
- Really basic question
- Current FSM links
- Motor Swap Converting a 3.4 L to a 3.0L
- ZUK mod, no lower bump stops, lots of rust
- 1990 xtra cab roll cage?!
- Just bought a Diesel, Any groups here enthusiastic the 2L-TE Toyota Engine?
- Crankshaft bolt
- solid axle swap 1991 4runner
- 90 22re truck massive oil consumption
- Thanks to all on this forum
- Manual tranny oil change??
- 3V-ZE Power Help
- 2000 4Runner AC/Heat control
- 93 Toyota Pickup RC 2WD - Ball Joint/Tie Rod/Steering Dampener Replacement
- ID this please
- question for tailgates for a new guy
- Burning Smell Before and After Clutch Replacement
- 93 Toyota Pickup RC 2WD - Body Lift/Bumper Bracket Question
- Automatic transmission fluid
- 88 4runner newbie needs help, multiple electrical issues
- buying advice wanted '85 4x4
- '86 pickup Cranking trouble
- Camshaft Squealing?
- 1987 Toyota SR5 Trucks 4WD Xtracab 4-Spd Auto ECT - Full Exhaust System Cleanup
- Cinder Block
- 22r install question
- 1987 22r Troubleshooting
- Jacking Up the Engine
- 22r-e clutch hydraulics
- Help 92 or 94 Toyota pickup two wir plugs under air intake desperately need help
- Alternator belt r and r
- E brake cable r and r
- 22RE Timing chain to short
- Body Lift Questions PLEASE HELP!!!!!
- ID these sensors please
- 1990 Toyota SR5 4x4 Pickup Radiator Replacement
- 3.0 engine connections differ?
- 22re head gasket?
- In the market for a 4runner
- 91 Toyota pickup clutch switch
- Change in driveability going from 35s to 33s
- Slave Cylinder Bolt Replacement.?
- Older Toyota engine comformation help
- Does anyone know what this part is called
- 1982 22r engine block drain plug size
- Removing a spool in a previously re-geared rear differential: Identify diff/carrier
- Center console
- What size tires for 1st Gen 4Runner with 4" suspension and 3" BL?
- i'm selling my ford and buying a toyota
- hello all, new guy here needs help
- flywheel removal
- 1983 sr5 4x4 build
- 3rd console switch 89 4runner
- 1989 22re new timing chain 7000 miles died
- Transmission problems
- Looking at buying a 1985 pickup with 22re and 5 speed
- Planning head gasket / timing chain replacement - need advice on parts
- '98 Tacoma possible alternator issue | Troubleshooting advice
- Budget 85 4Runner lift
- Using a Welder on Broken Bolts
- Alaska Heater / Blower bad?
- Tuning Trouble! NEED a Solution!
- 90 6 cy 3.0 VZE auto Winnebago Overheating
- Blew a spark plug of the engine
- splash guards
- engine swap??
- Upper ball joint troubles
- 86 4runner HELP a newb out!!
- Knock sensor issue after replacement of parts. Hard wire to ecm?
- 87 4Runner Engine code, rough idle, possible miss? Help!
- 3.0 rev limiter
- First gen - IFS lift install questions
- Weird Tundra Issues
- Somewhat Basic Questions (89 PU, 5 SPD Manual, 22RE)
- 92 Yota pickup throttle slam/jerk
- Oil catch can installed, now cel p0171
- 3.4 and automatic for heavy towing
- 2002 4wd Wont start
- Best lift option?
- Timing replacement trouble
- 1994 Toyota truck gearing
- New Yota owner with questions
- Do I need a new Axel?
- 22R Engine Year Help
- Ignition module and coild (1984 22r)
- OK to align wheels by eyesight?
- four wheel drive
- Ecu Problem
- changing oil pan gasket
- Transmission Filter Bolts
- Tacoma on 33 tractor tires
- Can you clean the A/C coil without removing it?
- 12 prerunner 3"lift Toyo AT 265/70 R17
- 1990 Toyota Pickup HVAC Fan / Installation
- help me identify these hoses and wires on my 22re 4runner
- Torsion bar adjust off drivers
- 1994 Toyota truck rear brake lines missing
- 2" body lift?
- Need louder exhaust
- 01 2.4L tacoma frustrated
- 3.4 swaps
- 88 pickup 3vze fuel line order?
- 1977 Toyota Chinook
- Transmission Gremlin
- Radiator for a 1994
- 89 pickup left tail light not working
- Timing belt question
- rough idle t100 3.0
- Arizona AC
- rear axle brake line
- 1991 Toy Itasca Trans stuck
- Hey all!
- 2LT clutch question
- 88 pickup 4x4 ?'s
- 1987 Truck problem
- fuel tank locking ring
- 1991 Toyota pickup 22re won't pass smog
- Lower your truck for free?
- T100 1993 speedometer
- 22RE LOUD Knocking Sound from Engine
- Remove and replace shifter handle?
- diff locks and little more
- 88 Toyota Pickup Squeaks When Cranked
- Radiator fan
- 1995 4 runner .Windows and door locks no longer work
- Oil Pump Question
- Steering Wheel Squeak
- Rear end noise and feel
- 99 Toyota 4runner abs/brake issue.
- Help Me Identify My Head that needs replacing!
- 1977 Hilux Project
- what brand power steering pump?
- Engine cuts out 22re
- 88 pick up battery light on
- 94 Toyota fuel pump problem
- Code 52 Vanished
- 3.4 swaps
- fsm-cylinder head rear plate
- 87 to 89 22RE swap
- Extended Ball Joints??
- 22re EGR question - simple
- what is FSM
- 99 toyota 4runner low idle on cold start up
- needed torque information
- 1988 4runner
- inch pounds to foot pounds
- 22re complete exhaust: please advise
