Sponsored by: CARiD
What to do with the radiator- 350 Conversion options?
Old Dec 23, 2015 | 08:27 PM
chevota91's Avatar
I have a 83 Toyota and am putting a 350 in it what is the best option for the radiator placement? What radiator works best... Pull or push fans which works better... Thanks first v8 swap
Old Dec 30, 2015 | 07:59 PM
chevota91's Avatar
Should I order the aluminum advanced adapter radiator or is there a better cheaper way? Thanks for the help?
Old Dec 30, 2015 | 10:16 PM
dropzone's Avatar
Fossilized
you will probably find your answer here (it might take a little effort but I am pretty sure it has been covered)
https://www.yotatech.com/forums/f158/
Old Dec 30, 2015 | 11:40 PM
wyoming9's Avatar
Red face
It really depends on just what your end use is going to be.
Will this be a Impressive Mall Crawler that sees the far ends of the parking lot??
Off road vehicle that could be hours from help ??
These things play an important part in figuring out just which materials to use.
Old Jan 5, 2016 | 06:50 PM
ZUK's Avatar
ZUK
Aluminum radiator in stock position....fan shroud.....centrifugal fan clutch. If you go electric fans then you take your chances. You risk overheating followed by a headgasket job.
gillesdetrail
Mar 20, 2016 05:18 AM
94yotaky
9
Feb 22, 2016 02:39 PM
MYV84B
Jan 8, 2016 01:57 AM
Jason H
Jan 1, 2016 11:00 AM
