View Full Version : Newbie Tech Section
- Help w/wiring URD 7th injector!
- trans/shifter spring help
- How difficult is it to fix an oil leak by replacing the oil filter housing & oil pan?
- 22tec help
- rear end
- New to yotas mines running rich
- Is the airbox required for a snorkel?
- Vibration @ 65 mph w/ driveshaft taken “OFF"
- trans
- 22re+turbo+tunning ?
- Transmission Swap question
- Timing Chain Bandaid?
- drive line mount
- Transmissions?
- Transmission rattle 5spd
- Dumb noob question.
- Rebuild Toyota 22RE nets loss of power
- Looking for stickshift cross section (recent)
- Advice choosing a long term project Truck vs 4Runner vs Cruiser
- generation question about Tacomas
- new owner of '87 4runner beater project
- Over heating
- 2001 4RUNNER - cool HEAT after waterpump change
- my headlights affect my idle and exhaust issue
- Anyone selling a transmission
- 1985 Toyota 4x4 Help with stalling/sputtering
- Convert '87 22R from 4WD to 2WD
- Newbie needs help. Coolant in oil possible timing chain issue?
- Spider gears
- full floater
- Truck problems Please help
- baja style suspension
- Sputtering 4runner
- Whats your dream rig?
- Mickey thompsons for my 2000 tacoma
- Am I reading these error codes wrong?
- 2 cooling fans??? one is on one isnt??
- 1st gen 4runner questions
- Need A tailgate
- 1988 toyota pickup 22re 2wd solid axle swap
- 81 Pickup should I buy it?
- Is it worth it?
- 79 pickup 4x4 short bed
- 22r Carburetor problem and California smog
- Leveling kit advice for 2007 Tocoma TRD-sport
- 1982 toyota 4x4
- A legit place to buy little odd parts
- Best Soild Axle Lift Kit 85' 4x4
- rock/dnj engine parts
- Slow Idle, Significant Power Loss
- 86 22r idles but won't drive after running out of fuel
- My yota
- best engine in your opinion?
- Metallic rattling noise under acceleration
- V-Belt
- O ring for crank pos sensor (dealership does not show it)
- Your Typical Newbie Questions, or may be NOT
- 83 motor goin in 85 4runner wiring
- headgasket replacement questions/concerns
- 1985 22r no compression
- Maintainance on a 2001 Toyota prerunner 2.7L
- 87 TOYOTA PICK UP 22RETURBO EFI FUEL INJECTION EXTREMLY RARE STOCK FROM FACTORY 4x4 1
- Help
- My project toyota
- Need help removing the heads from exhaust
- fuse keeps popping, I need help..
- 1985 Toyota Pickup- need ideas on lifts/gears
- 94 toyota 22re
- Best place for parts
- 4.70 gears with a doubler ..
- Over heating on 4x4
- Newb needing advice for 4runner purchase
- persuading an A340H to shift...
- Engine block warmer
- Front windows not working
- What's the deal with Generations?
- Locker
- Truck or 4runner? Need help
- Elocker gear question
- Need small things...Have been hunting and nothing....
- Can't remove front license plate 89 4WD truck
- Interior parts
- 22re high idle and pushing out coolant after shutoff
- 22re idle high and pushing out cooland
- Transfer shifting sticker on glovebox
- 1988 22re wont start, VSV wire broken.. related?
- not sure what GR i have, need to replace axle
- 85 runner no start
- Blown EFI Fuse
- Won't start/crank/turn over??
- Searched but nothing found on two clutch questions
- Best way to protect mint bench seats?
- Noob Frame/Radiator Question
- worth a new carb and engine ring rebuild?
- My 4wd is not opperating right?
- Hey guys! Intro post/82 pickup carb questions
- L.E.D. light bulbs
- Crankshaft Pulley Bolt Stripped
- 22r possible blown HG?
- after market solid axle
- Ecu and code problems!!
- Ring and pinion for land cruiser
- New 86 Pickup Frankenstin Truck help
- 1990 pickiup 22r skipping
- 22r burns oil on startup
- getting my first truck tommorow but it dosent run electric prob
- My speedometer doesnt work.HELP
- 91 solid axle swap I need advice on how to go about this project.nb
- Intermittent stutter/sputter 22RE
- Newbie TPS setting question
- Please Help-4 newbie questions
- Two inch bracket lift kits, do they exist?
- Rear Anti-Lock indicator light
- 93 Toyota pickup 22re no injector pulse
- How bad to do control arms?
- Valve Cover Gasket Replacement Questions
- 3VZE NOT reaching operating temp
- EGR Sensor
- Problem with 22r and lift
- neautral safety switch how can i tell if mine is bad
- 92-94 3vze differences
- new ps pump but no powersteering
- Backpressure?
- '92 Toyota 4×4 that was changed from EFI to a carburator, many problems, solid truck
- `93 4Runner Hatch Problem
- Any ideas where to get fuel level sending unit!?
- coolan
- BEST Weber Carburetor Conversion Kit Prices
- think I found my fuel gauge problem
- Noob AFM question
- 3.4 supercharger lacks power
- EFI Fuel Filter
- Concerned about a 22r in the mountains...
- 2wd mojave pickup converted to offroad camping trailer
- 22RE cuts out during acceleration.
- Snow wheeling
- 2010 Tundra leveling kit
- Fuel vent lines
- 22re lift kit question
- One of those not that question again question
- Engine getting hot before thermostat opens
- Trimmed fenders
- Little filters on valve covers?
- Front grill assembly
- Brake issue?
- 89 Toyota pickup buzzing sound
- Transfer Case - Re-gear VS Double Stack?
- 22r distributor vaccum advance
- 90 pickup Hood release issue
- Removed Supercharger back to stock intake- High Idle
- Shoot, Dang and Heck. Help!!!
- 22re performance at high altitude... what's your experience been?
- 85 Toyota swap suggestions
- Power Steering Pump Pulley
- 86 yota gear shift collision.
- Engine smoking from head?
- Gas tank issues
- Having a Brake Issue
- Slow accleration
- 22re adding turbo
- 3rd gen 4Runners grilles interchangeable?
- 160 pt Inspection or Straight to Mechanic?
- Timing Chain replacement
- No electrical power of any kind! 92' pickup
- 2004 Tacoma problem
- I'm New!!!
- Asian carburetor float bowl needs adjustment, running rich
- water spraying out of radiator.
- Supra LSD Qs
- side draft carb kit
- Building a hunting rig and dont know where to start.
- 3.0l runs and shuts off after 5 seconds
- Selecting a Pickup... which year?
- Another Classic Body Lift Thread
- Air intake issues after install
- gear ratio for lockers
- Took axle out to replace inner axle seal, some wear on birfield knuckle
- tcase popping out of 4wd
- 84 Truck 4x4 Inner front axle seal replacement.
- Replace Rear Main Oil Seal
- Rust repair without welding
- 1995 and newer wheels on a 1994 pickup?
- 94 3.0 Clutch engagement issues after replacement
- Transmission jack placement?
- 95 3vze timing mark jumps and no ne signal at dizzy while hot. Help.......
- Mystery issue (again)... Need help troubleshooting.
- 22RE wonky idle, now won't start
- How do I measure a clutch?
- 99 4runner hesitates. No code.
- 91 4runner ac delete
- Help! Truck caught fire!
- Distributor location
- 96 Tacoma Dash Removal and Assembly
- fuel injected 22re idle problems
- Wheels and Tires Question: 12.5" wide tire on stock 7" wide rim
- 2004 Tacoma Prerunner Bushing Questions
- First Yota
- Clutch brand
- 1991 toyota truck starting issue
- So many mixed thoughts on gear ratios
- Help 92 4runner issues (overdrive)
- Help with transmission troubles.
- wondering any home body lift
- Any ideas on a no start condition for an 85 4runner
- 1990 Toyota Load Sensing Proportional Valve
- Remove 96 Tacoma Dash ??
- New Member
- Have a chassis question...
- 1995 Runner won't start, but I don't think it's electrical
- IFS inner axle seal replacment info needed
- Speedo plastic gear p/n
- shavings in my hub!
- 86 4Runner - No start Part II
- 89 4runner, takeing time to fire
- 91 Tacoma Bull/Push bar
- Help!! Convert my 99 runner into a pickup
- Coolant system. Need some input on this.
- need advice!
- 94 toyota 22re
- Fuel line issue during 3.0L engine removal
- 82 Frame on a 84 Truck
- What is a sucked Valve?
- New Clutch, Shutters in first
- tps sensor
- some people dont get it
- Double Cardan Trouble
- super springs and leaf springs
- 1990 4x4 pickup with no fire
- Speedometer issues
- Thinking Powertank , make my own , other OBA options?
- Winch mounting
- Can any one identify this rear end?
- Will 35s fit mall queen with BJ spacers and rear OME?
- 1983 22R timing Chain question
- wheel bearing PN
- Cab lift points?
- hi i need a o2 sensor identification
- What is in the picture?
- Rig won't start, jumper cables hot...
- R151 and RF1a fluid/oil specification
- Clutch Problems
- New member in need of knowledge
- starter relay
- Clutches
- no power to fuel pump
- 95 Tacoma Engine Miss
- Starter for 4Runner 93, V6
- 2001 Sequoia Rear Window cold weather issue
- Timing issue 1989 22RE advice.
