Sponsored by: CARiD
Double Cardan Trouble
Old Dec 11, 2012 | 10:12 PM
dallen006's Avatar
need all info on double cardan joints u can give. Center of my joint was rusted and broke off i think. I just got this 97 toyota tacoma in June. a guy at the shop said the part needed to be made and ordered special because toyota didnt make replacement parts for it. how to i fix this or is there a cheaper way.
Old Dec 12, 2012 | 01:23 AM
bobcat86's Avatar
There shouldn't be any need for that part to be made. I just went through this process last night on a customers Jeep and I got the part from a driveline shop, so that would be where I'd suggest ya start first. The part cost less then 40$ and didn't take too long to swap out. If you plan on tackling it yourself, you'll need a vise, a pair of sockets and needle nose pliers. If your unfamilliar with changing u joints, pm me and i can walk ta through it. Hope this helps.
Old Dec 12, 2012 | 05:30 AM
waskillywabbit's Avatar
Didn't make replacements for it. Right.
Wanna buy ocean front property in Arizona?
:wabbit2:
Old Dec 12, 2012 | 06:03 AM
MudHippy's Avatar
Not that there aren't ways of replacing the double cardan(with one that will work just as good as stock), but Toyota will only sell you a replacement as part of an entire Propeller Shaft Assembly(w/ Center Bearing). And will not sell you any parts for a double cardan, AFAIK. The prop shaft assembly is ~$1036.
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Oct 2, 2015 07:47 AM
Matthew Perez
Sep 28, 2015 05:43 PM
Ilovemountains
Sep 15, 2015 04:17 AM
128keaton
Sep 3, 2015 05:09 PM
