Sponsored by: CARiD
My speedometer doesnt work.HELP
Old Jan 16, 2013 | 06:06 PM
yota1016's Avatar
I have a 1991 4runner and all of my gauges work accept my speedometer...the previous owner messed with the odometer and so idk if it messed it up, I haven't taken it apart yet but was curious about any ideas? Please and thanks
Old Jan 16, 2013 | 06:21 PM
StewsRunner's Avatar
Does your odometer work? Pull your tach out and drive around the block and look at the needle in the speedo cable. If it spins, the tach or VSS which is in the tach, is bad. If the needle does not spin, your cable snapped, simply replace.
Old Jan 16, 2013 | 06:45 PM
yota1016's Avatar
My tach does work.
And could it also be as simple as an electrical problem? Or is it most likely that cable?
Old Jan 16, 2013 | 06:49 PM
Well IIRC the vehicle speed sensor is actually in the tachometer and I do not think you can replace it, you need to replace the entire unit. I'm sure it's one of the few. Very simple check.
Old Jan 16, 2013 | 06:50 PM
yota1016's Avatar
Ok thank u.
Phantez
Sep 30, 2015 08:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Rickstwowheels
Sep 21, 2015 05:21 AM
matt1833
Sep 16, 2015 07:11 AM
toyotafreak98
Sep 10, 2015 02:57 PM
