View Full Version : Newbie Tech Section
- IFS swap
- 1991 Pickup Can't get OB1 codes
- 1989 Toyota Pikcup 22R or 22RE
- 3 piece grille on an 89 2wd pickup
- Is this repairable?
- L52 Rebuild Problem
- 1994 Pickup Bed
- oil change history when buying used car
- 4runner 4WD transmission
- 87 Toyota turbo pickup wiper relay location
- Help please!
- Toyota engine
- 99 tacoma blinker issues
- altitude adjustment needed??
- 05 Colorado engine swap
- Mystery electrical connectors and more!
- 1982 pickup wheels
- Wiring harness compatability
- What is this wire?
- Sunroof Stuck Closed
- Headlight Warning Buzzer....
- 2000 4Runner 3.4 random misfire in 1,2,3
- What component is this, it's function, and how do i test.
- AC / heater - all new parts or piecemeal?
- 22re bucking and won’t accelerate once warmed up
- 93 Toyota 4x4 pickup automatic trans V6
- Freeway RPM Question on FJ Cruiser with 33" tires and 4.88 gears
- 2006 Tundra Driveshaft Replacement
- Where does the O2 Wiring go? (yes, another 02 sensor thread)
- Dumb question
- Can I cut in here and install a triple gauge?
- Dead Cylinder
- Imported land cruiser
- 1976 Chinook
- 1987 toyota 1 ton truck bushings
- Have I been punked? Where are the oil sender and sensor?
- Noob researching toyota drivelines
- Help me put this together please I want this to run again I'm just an idiot
- Offenhauser 6136 Intake & Holley 7448 2 barrel carb
- 1999 toyota proprietary diagnostics tool
- 3rd member unthreaded hole
- Double nut method.... Now what?
- Cat Back Exhaust
- Need Help Identifying Battery Cable Connector (1986 22r 2WD)
- 1990 22re toyota pickup
- Installing sound system 85 pickup
- 1983 Toyota with new carb is running really rich?
- Did I mess up?
- Speedo gear help
- 2003 4wd Tacoma
- Truck cut off while driving
- Safe method for determining dual transfer case shift pattern
- No power to the fuel pump
- Where to buy aftermarket parts?
- Ignition cylinder not working properly
- 2007 4Runner - Worth it?
- What do you think of these cracks in the edge of the tires?
- Killswitch installation?
- How to install aftermarket RPM gauge ?
- Transfer case fluid
- 93' 22re Pickup - Won't Start After Sitting
- 1998 to 2000 IK2 connector wire diagram
- 2009 Highlander is coding. Hopefully correlated...?
- Need to Buy or Rebuild 22RE - Advice Please
- t-100 3.0 to 4runner 3.0
- Wiring diagrams for 82 BJ44?
- Hub differences MM vs Aisin
- Motor swap
- should i remove BJ spacers?
- Can't get this shifter knob off for the life of me...
- Trans swap
- Electrical problems with 1986 truck
- Help! 3vze stumbling, low power CODE71
- What to look for when buying a engine block
- 93 22re cranks but not start
- Spindle
- Having problems with not starting
- Toyota Truck Help!
- Help!
- Painting
- 2010 Tacoma Chirping Sound
- 3.slow oil pressure gauge issues?
- 1986 Sunrader automatic - gear indicator wrong
- Front wheel bearing grease
- 95 3vze no power to injectors!
- Occasional hard start, backfire
- AC condenser difference
- Used parts
- 2000 4Runner struggles to start after short period
- 90 4runner electrical problem
- Doing my first rebuild...
- 20R Truck sounds like a john deer.
- Gear Contact Pattern: Please Advise
- Front breaks seizing while driving.
- 95 4runner rubber block by transmission
- Convert to EFI
- Distribuidor de encendido 90 y 92
- Egr?
- 3.0l diesel swap
- from idle to wot it bogs
- 83 Toyota 22RE Backfiring and Surging once warm
- Tire size
- Help with Lift Kits for a 2021 4Runner.
- Chasing an oil leak 88 Pickup
- Help with part exchange
- Rust
- 3.4 wiring
- Thoughts on this ring and pinion pattern?
- TPS placement
- 1998 Tacoma 2.7 stutters and backfires under load
- 1988 Toyota Pickup Tail/Dash lights intermittent
- 22re 2wd into a 22re 4wd
- Would a body wiring harness from a 2001 Tundra work on a 2000 Tundra? Different parts
- rebuilt 22r oil pressure issue.
- 81 22r into 86 22r
- 91 T4R heater and A/C removal
- Can you drop in a 22r and tranny mated without cutting radiator support?
- ADD plug??
- 1st Gen Tach gauge cluster differences
- 3.0 valve adjustment
- 22re engine starts then dies after a couple of seconds
- Trouble shootinf
- W55 transmission output shaft bushing removal tool, help I need.
- 1990 cab and chassis - Winnebago RV - engine harness eaten by rodent
- 22RE Major engine maintenance after 300k?
- 3vze engine dies after thermostat and drive belts replacement
- Front Suspension Feedback
- Shifting Problem and 4 Wheel Light Flashing
- Screw lugs on lower dash panel
- 22re Mass air flow sensor
- Fuel Tank Strap Challenges
- Steering Column Play?? not front end
- Frame rust prevention help!
- ABS issues...need to get this fixed asap!
- 85 4runner no crank
- Manuales 2000 SR5
- Toyota 22re new transmission output seal leaking, is the bushing needs to be replace?
- 86 4runner will turn over, but won’t start.
- Tps/ missing when warm
- Cam,header,.020 bore,egr delete. Computer issues
- 22re overheated and now cranks but wont start
- Grease zirc
- Automatic Transmission Viewpoint
- 22RE Camshaft cap bolt holes stripped
- 1987 Pickup won't start. Previously had idle issues
- 2005 4Runner Rear Window Reg Assem.
- Regearing my tacoma
- Need help 1993 Toyota 2wd 22re need power steering
- 86 Gas tank replacement
- Convert 99 Toyota pickup 4 to power steering
- 22re truck clutch master cylinder problem bleeding.
- Blown head gasket on 4Runner 1993 3.0 V6
- Code 12 questions
- '94 22re engine power issue
- Help! 1990 22RE 4cyl Pick-Up Kill Switch
- 1977 Chinook is dieseling
- O2 sensor 03 hylander rust repair
- 3rz-5vzfe conversion
- Leveling Kit
- Random open port on backside of moto
- starts for less the 1 Sec & die's! you let off the key & try to start it again
- Trying to find out what component this is
- 22RE Water/ Coolant in Oil Diagnostic
- Died while running// not the best 1st gen Tacoma
- 97 Taco fwd ac v6 radiator removal
- Whats is this part called not the motor mount but the metal cover
- I just bought this... guess the lift?
- ECU/ECM Swap Question!
- 20r not wanting to idle
- Is my head gasket blown on my 22RE??
- What's a good online source for ball joints tie rod ends
- Something inside oil pan
- Mystery hose winner gets prize
- Tilt Steering
- Thread stripped front differential drain plug
- How to reset the AFM back to oem settings?
- 22re no fuel issue
- 1993 nissan pathfinder ,automatic ,3.0
- 86 4runner Pillar/Windshield Rust
- 91 four runner won’t rev up
- Headers and body lift
- 1986 4Runner engine issues, where to start
- 1994 Toyota Pickup , 22re
- 1987 Blinker to Turn signal conversion
- Determine which Rough Country lift kit is installed
- 4wd shifter questions
- Starting issues
- Intermittent spark?
- Obd2 not working, need to set timing.
- 90, 4 runner. 22r, Vacume help.
- P0755 + No reverse
- Throttle Body Vacuum hose hello
- 81 lift kit
- Where does this wire go?
- 2002 tacoma 2.7L to 3.4L Cab Swap
- Hatch Seal Alignment Markers
- Lots of googling with no answer... trans/tcase help!
- So sorry... Help me diagnose my rattle
- Is my frame bent?
- find TDC on compression stroke
- Timing housing head gasket damage
- 3.4l (safe) top speeds
- blown head gasket/ timing chain engine swap
- sloppy shift lever in 86 4runner dlx a/t
- 86 4Runner
- Introduction and Post-Purchase Maintenance Checklist
- Hello, long time Yota fan from Oregon
- Temp gauge
- Motor swap
- Timing ? Stuck cylinder ? Throttle body backfire ? Need help
- Throttle cable question
- Just got my new cam in the mail
- Fuel pulsation after EGR/PAIR delete 3VZE
- Code 71 bypass?
- Major 3VZ-E to 22RE
- 86 pickup 22r cuts out when accelerating
- Neutral safty switch wiring diagram?
- 22re idle low
- 88 Toyota 22r
- 22r carb issues
- What to get for 3vz 4runner head gasket replacement
- 1988 Pickup 22R-E EFI
- Speedometer cable part help
- What to look for in a pick n pull 22re?
- R150F manual transmission drain and fill plugs
- 20R Smog Stuff
- 1979 2wd truck timing
- 1985 Frame Solid model in NX/UG
- What gen do I have?
- A/t p light on in 2hi
- 3vze Timing belt jumping
- Head Gasket Troubles
- Wiring harness the same for 90 to 95
- Identify a Radiator?
- Can't figure out why? help
- New to Toyota and this forum
- Who do you trust for part numbers
- What to do!
- What to do!
- W40 to W58 Transmission Swap Information
- 3rd gen seatbelt replace
- Altimeter installation
- How hard is it and how much does it cost to go from a 4.10 gear ratio to a 5.29 gear
- My low mileage 94 T100
- Brake issue.. I’m driving a death trap at the moment
- 1986 Toyota Travelmaster Motorhome
